enabling DRL
Old Jun 14, 2007 | 10:30 AM
fordmanss12's Avatar
fordmanss12
enabling DRL
Background: I'm from Canada and it's required. I have purchased a US vehicle 2007 F150.
My questions:
1) Is the wiring in place for the DRL but the module will need to be installed?
2) If the wiring is not in place (behind the left headlight) will I need to purchase a 'kit'?
Thanks
Old Jun 14, 2007 | 07:22 PM
kd4crs's Avatar
kd4crs
The wiring and relays are not included in the US version F150. You will have to add it as an accessory. Ford sells the kit for about $80 US.
Old Jun 16, 2007 | 07:32 AM
fordmanss12
thanks. Is it a straight forward installation or does the dash have to come apart?
Old Jun 16, 2007 | 08:24 AM
Turbodog1000's Avatar
Turbodog1000
I bought the DRL adapter unit, it has 5 to 7 wires to hook up under the dash. I thought "no problem" but it turned out to be a bigger job than I wanted to do.
The truck was BRAND SPANKING NEW and could'nt bring myself to chop into the wire bundles.
The quick fix is, if you have "AUTOLAMPS" you can just put a piece of black tape on your daylight sensor, and leave the switch in the autolamp postion.
In the manual, it has a procedure to change the time that the lights stay on after you shut off the truck. I have changed mine to 1 second.
Old Jun 18, 2007 | 10:01 AM
fordmanss12
thanks turbodog. Do you happen to have the part # of the kit? My local ford dealer says there's no such thing...
Old Jun 18, 2007 | 10:40 AM
fordmanss12
is it possible the wiring/module is in place and the dealer can activate drl by configuring SJB to enable the DRL with WDS?
thx
Old Jun 19, 2007 | 10:15 AM
fordmanss12
can someone provide the kit part #? Dealer says Not available. is it the same kit that the 06 uses?
thx
Old Jun 19, 2007 | 02:41 PM
Turbodog1000
fordmanss12,
The DRL unit is a generic unit that will retro-fit many different ford products. it is a stand-alone unit. I am currently out of town. but when I get back on june 28 I can get you the part number. If it will work in your truck I don't know. If you have a paypal account I will be glad to sell it for $25.00 plus shipping.
Old Jun 19, 2007 | 02:59 PM
fordmanss12
thanks turbodog1000. I don't understand why they're saying it will work up to 08/2005 F150, but not after that. I would assume it's a generic thing, unless it won't work with the auto headlamp system...
thomabb
Electrical Systems/Wiring
Feb 1, 2020 07:57 PM
comsupany
May 16, 2016 12:56 AM
kyle_in_rure
Jul 3, 2015 06:37 AM
rorr1821
2009 - 2014 F150
25
Mar 3, 2012 06:46 PM
fordmanss12
Jun 19, 2007 10:52 PM
