Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Running lights flashing
Old May 18, 2016 | 06:41 PM
ratedterror's Avatar
ratedterror
I changed to drl module and relay with a replacement taken from an auto wrecker. Lights are still flashing, Should I say I have bad luck and got another bad one? Typical drl module symptoms, lights stop flashing when you pull the e brake. Or turn head lights on. So try one more drl module?
Old May 19, 2016 | 06:30 AM
tomw's Avatar
tomw
My understanding is that the DRL essentially flashes the headlights on and off very quickly to produce a reduced light and make the vehicle more visible to other traffic/drivers.
I suspect you are two-for-two in having broken modules. Does the yard guarantee their parts for 30-90 days? They should do at least a 7 day... or as long as it takes for you to install and verify it doesn't work.
I do not know the test procedure and have no doc on how it should be done.
tom
added: Having posted the same question here and escape central, which seems to give the most response?
Old May 19, 2016 | 07:47 PM
ratedterror
Definitely this site, I had the question on escape central for a few weeks with no response.
Old May 28, 2016 | 10:59 PM
Rustynice's Avatar
Rustynice
When you turn on your blinker do all of your lights blink irregularly as well? If they do it could potentially be a bad ground.
Old May 29, 2016 | 12:49 AM
ratedterror
blinker, you mean the hazards? the hazards function normally. Got another modual and now the daytime running lights don't function at all. Swapped back to the old drl modual, no flashing, nothing so who cares, don't need em anyways.
CA-F250
6.7L Power Stroke Diesel
Oct 6, 2010 06:37 PM
jam105
South Carolina Chapter
Dec 6, 2007 08:44 PM
jddun123
Jan 11, 2006 10:16 AM
quadman
Jan 12, 2003 09:45 PM
arrowstar
Aerostar
Feb 17, 2002 11:26 AM
