brake rotors
Old May 28, 2010 | 05:33 PM
riverratba's Avatar
riverratba
brake rotors
i have a 2007 F150 supercrew,the front wheels are starting to shake when i get on the brakes. i think its probably the rotors. are they hard to remove? will they slide off after you take the calipers off.
Old May 28, 2010 | 05:44 PM
390XR7's Avatar
390XR7
4x4 yes,4x2 no
Old May 29, 2010 | 12:33 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
had no problems getting mine off 4X2 last month to change them.
Old May 29, 2010 | 01:05 PM
Oldguy4's Avatar
Oldguy4
I think 390XR7 meant that on the 4wd, the rotors just slide off where on your 2wd they are integrated with the hub, so not quite as easy.
Old May 29, 2010 | 06:32 PM
Greg B's Avatar
Greg B
It's a lot easier than a spark plug change.
Old May 29, 2010 | 10:05 PM
390XR7's Avatar
390XR7
ya what he said
Old May 29, 2010 | 10:55 PM
riverratba's Avatar
riverratba
thanks everybody! so i guess the hub nut holds the rotors and hub on. anything i need to know about putting the hub back on,preloading the bearing?
Old May 30, 2010 | 10:50 AM
2004 xlt 5.4
you did not say if your 4x4 or 2x4
i can only answer for 2x4 the bearings come with the rotor no grease added they are ready to install should replace the spindle nut 36 mil. and needs to be torqued to 295 foot lbs.
not sure the specs for 4x4
Old May 30, 2010 | 01:43 PM
riverratba's Avatar
riverratba
i have a 2X4, thks for the info!!!
Old May 30, 2010 | 02:26 PM
Greg B's Avatar
Greg B
And new spindle nut each time rotor comes off.
Brown Falcon
Oct 4, 2011 01:31 PM
hydrosmith
Nov 29, 2010 09:28 AM
oldhokie
Escape & Escape Hybrid
Oct 16, 2007 04:27 PM
ckrichard
Dec 12, 2003 08:47 PM
