4wd brake rotor question...
Old Oct 2, 2011 | 07:20 PM
Brown Falcon's Avatar
Brown Falcon
Ok, The hub is off, the studs are out.... HOW DO I GET THE FREAKIN ROTOR OFF!?!?!?!?
Sorry, kinda frustrated.
Old Oct 2, 2011 | 09:39 PM
rideracelivemx7's Avatar
rideracelivemx7
just smash at it, its just frozen on there. the bolts press it in when there zipped on there and theres probably a small rust seal. get a piece of wood and go to town.
Old Oct 2, 2011 | 10:28 PM
Brown Falcon
Which way does the hub come out? Towards the outside or the inside?
Old Oct 3, 2011 | 06:49 AM
62uni4x4's Avatar
62uni4x4
the hub drives to the outside.
Old Oct 3, 2011 | 11:03 AM
Brown Falcon
Cool. I'll go out and beat on it later...
Old Oct 3, 2011 | 01:30 PM
Talyn's Avatar
Talyn
couple 4x6's help for this stuff to set parts on.
the fit is fairly tight to begin with, and rust makes it hook nice.
Old Oct 3, 2011 | 09:56 PM
Brown Falcon
rotors are off, measured them and there's lots of meat left so I'm having them turned tomorrow. $16 total to turn them vs. $60 for new ones
Old Oct 4, 2011 | 08:51 AM
Fullcrew7.3's Avatar
Fullcrew7.3
Good news indeed Evan. Thanks for the continuing updates as well.
Old Oct 4, 2011 | 09:51 AM
Brown Falcon
My 4x4 conversion parts list is getting smaller... slowly.
New axle u-joints are in, new balljoints are getting pressed in within the next couple days, then I can put the front axle back together completely.
Now I need to buy the Sky 3" RSK $300, cast iron 4R100 tailshaft $100, and new front spring u-bolts $50. I'm debating on whether I'll need a add-a-leaf for the springs from my '87 I'll be using, that would be another $100.
I'm just worried that the front end would sit too high with a add-a-leaf in there. The springs seem pretty soft and sat fairly low with the 6.9 on top of them, but it also had a dana 50 axle so it would look another inch lower compared to a 60. Maybe I can buy the add-a-leaf and just have it ready to go in when I install the axle and send it back if I don't need it....
Old Oct 4, 2011 | 12:27 PM
joe_13894's Avatar
joe_13894
I have a set of 2" lift spring that came off a '94 F250. They look quite stout.
Old Oct 4, 2011 | 01:31 PM
Brown Falcon
That's the thing, with the 3" RSK it should make the front level (with stock springs) with the rear (with the 4" factory blocks)
So if I put a lift spring in the front with the RSK it'll sit too high. Plus the F250 springs were a lot stiffer than F350 springs because the TTB front end twisted too much with softer springs.
I think the springs I have are going to be ok, if anything it will sit an inch low in front which is ok by me, and it'll have a softer ride. I can always do an add-a-leaf later on I guess.
pavementpounder96
30
Jul 12, 2022 03:35 PM
Memphis_Sean
Apr 8, 2014 12:16 AM
mudslinging79
1978 - 1996 Big Bronco
Mar 5, 2014 09:36 PM
rmccoll
2004 - 2008 F150
Aug 24, 2011 11:33 PM
xsquid3
Oct 4, 2006 01:46 AM
