Brake questions.
Old May 25, 2010 | 10:21 PM
flipklos's Avatar
flipklos
Brake questions.
Does anyone know the minimum thickness that the rotors and drums on a 85 F150 can be turned to? I have to knock them off to change pads and shoes and doubt they have ever been turned so I was going to chuck them up and turn them. I realise that it is supposed to be stamped into the steel but the pitting is pretty bad after 25 years.
Thanks.
Old May 26, 2010 | 12:30 AM
Franklin2's Avatar
Franklin2
F150 2wd
Max drum diameter prior to machining 11.090 inches.
Drum discard diameter 11.120 inches
Drum nominal diameter 11.030 inches
Front disc minimum thickness before machining 1.150 inches
Front disc discard thickness 1.120 inches
Front disc nominal thickness 1.185 inches
Old May 26, 2010 | 06:28 AM
flipklos's Avatar
flipklos
I should have mentioned that it is a 4WD. My bad.
Old May 26, 2010 | 07:48 AM
Grubbworm's Avatar
Grubbworm
The minimum thickness should be stamped on the rotors and drums.
Old May 26, 2010 | 09:23 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Or cast into them.
-Enjoy
fh : )_~
Old May 26, 2010 | 09:26 PM
flipklos's Avatar
flipklos
I think I mentioned that they are illegible due to pitting.
Old May 26, 2010 | 10:33 PM
Rogue_Wulff's Avatar
Rogue_Wulff
You must be assuming that anyone else actually read that far into your post......
Sorry, I don't know the exact specs for the 4x4 front rotors, but I'd bet they are very similar to the 2wd, since the pads/calipers are the same. Rear drums would be the same, as the are the same parts.
Old May 26, 2010 | 10:48 PM
Franklin2's Avatar
Franklin2
F150 2wd
I checked, 4wd is the same.
Old May 27, 2010 | 06:29 AM
flipklos's Avatar
flipklos
Thanks, I will mic them up.
Old Jun 6, 2010 | 09:59 PM
flipklos's Avatar
flipklos
Rotors were shot. One side had pads worn at an angle. Replaced rotors and pads.
Drums looked ok. No adjuster cable though. Installed adjuster cables and now have very, very good brakes.
Thanks for the help yall.
rdinmv
Feb 4, 2014 08:52 AM
andrewbragg
May 22, 2013 04:42 PM
kconrad
Nov 12, 2012 03:14 PM
little boatman
Electrical Systems/Wiring
Nov 5, 2008 06:17 PM
fender72
Jul 17, 2007 11:56 PM
