Sponsored by: Real Truck
daytime running lights
Old May 19, 2013 | 10:15 AM
andrewbragg's Avatar
andrewbragg
I have an 01 f350, when I turn on the truck the daytime running lights turn on immediately, how do I get them to not turn on unless I turn on headlight switch?
Old May 19, 2013 | 12:37 PM
68 351 bronc's Avatar
68 351 bronc
You should be able to just pull the running light relay. It should be located behind the glove box door, infront of the heater box. There is also a fog lamp relay in this same relay box if you have fog lights also. Your headlights should function normally without the relay.
I havn't tried this so if it doesn't work just reinstall the relay.
Old May 19, 2013 | 02:12 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Out of curiosity, does your door sticker have a maple leaf on it?
Old May 19, 2013 | 07:36 PM
andrewbragg
It worked, was more up then in front of. Appreciate it.
Yes my truck is Canadian
Old May 22, 2013 | 12:37 AM
STEVES68NOVA's Avatar
STEVES68NOVA
If I do not have DRL, can I just install the relay to get them?
Old May 22, 2013 | 04:42 PM
FarmingF250's Avatar
FarmingF250
https://www.ford-trucks.com/forums/1...sable-mod.html
I did the above. Manual disable/overide the DRL, didn't like my DRL on while cranking in the winter, or when parked.
Bruker
General Automotive Discussion
18
Dec 28, 2019 06:48 PM
GG63Slim
1997 - 2003 F150
Jan 2, 2013 10:14 PM
FIREBALL 00
1997 - 2003 F150
Jun 14, 2011 11:29 PM
whitesdford
May 14, 2007 08:51 PM
02sd
Oct 13, 2004 05:04 PM
