ABS lite off!
Old May 25, 2010 | 07:04 PM
ctango01's Avatar
ctango01
ABS lite off!
Finally got time to install new ABS sensor on rear diff. Lite has been on since about last july. First it was the front ABS. Paid a lil over 100.00 for front. Then about one month went by came on again. Went and had it checked out was rear abs. So i just rode it thru the winter. about a month ago i changed the rear diff grease. Wasnt full of metal but was quit dirty. Had my parts guy price the rear abs. kept telling me its over a hundred. Well they was wrong. They kept ordering the pice but kept ordering the wrong piece. Finally yday i got the right abs sensor...from ford it was $28.91. Just wanted to say that i finally got my "black beast" fixed.
Old May 26, 2010 | 04:49 PM
MikeVT's Avatar
MikeVT
Did you ABS come on or stay on all the time. My light comes on as soon as the motor starts and never turns off. I thought it would go out until you started driving if the sensor were bad.
Old May 26, 2010 | 07:02 PM
ctango01's Avatar
ctango01
When you started the explorer it came on with iginition. Never did go off. The 4x4 high flashed sometimes maybe 8 times then went off. But the ABS stayed on from time of igintion until you tured the motor off. I changed the diff oil once then put new in ran it for about 2 weeks. about 250miles? then changed it again when i put the new sensor back in.
Old May 26, 2010 | 09:34 PM
gdunn's Avatar
gdunn
My abs light came on today and my speedo only works when I am coasting! Any Ideas?
Old May 26, 2010 | 10:49 PM
shorod's Avatar
shorod
Some Fords source the vehicle speed from one or more ABS wheel speed sensors. Since you don't mention the model year of your vehicle I don't know if yours is one of them, but based on your description of the problem it seems likely.
-Rod
Old May 27, 2010 | 12:46 AM
gdunn's Avatar
gdunn
Sorry about the info not being there! Its a 1999 SD f-250 4x4 TD 7.3 with only rear anti locks.
I just want to say thank you for your help!!!!!
Gary
Old May 27, 2010 | 07:50 PM
ctango01's Avatar
ctango01
Id check the abs sensors on all 4 wheels. I dont rember if they are on all 4 wheels. Ill have to look at my dads tomorrow. Hes got a 2002 F250. Some tiems you can take them out and clean them and install and it fix problem.
Old May 28, 2010 | 07:03 AM
shorod's Avatar
shorod
If your truck just has rear ABS, you will not have sensors at all four wheels. You will only have one sensor which is located at the rear differential input.
According to the 2000 Factory Service Manual, the Vehicle Speed Sensor is part of the ABS system, even if you just have rear ABS. At least on the Explorers the rear wheel speed sensor is a common part to fail. It's probably a similar situation on your F-250, and the problem is likely the wheel speed sensor.
-Rod
Old Jun 2, 2010 | 09:36 AM
gdunn's Avatar
gdunn
Thanks guys,
It's fixed and it was the rear sensor. Cleaning it did not work but replacing it did.
Thanks again for all your help!!!!!!!!!
Old Jun 2, 2010 | 06:51 PM
ctango01's Avatar
ctango01
Glad we could help!
jaycenk
Jul 4, 2012 05:55 AM
ctango01
Apr 24, 2010 12:52 PM
claudiucenan
Escape & Escape Hybrid
Oct 27, 2009 02:19 PM
nlemerise
Aug 30, 2007 12:58 PM
