cruddy day
Old May 26, 2010 | 06:09 PM
  #31
powerstroker100's Avatar
powerstroker100
yes the V ended fuel line I am going to do but am stuck on what to do with the bobber It isnt steel so I cannot cut it and shorten it but feels very brittle if I try to bend it, I'm going to try and bend it, wish me luck
Old May 26, 2010 | 07:51 PM
  #32
powerstroker100
alrighty fixed the bobber problem now going to find out how to get the lockring on
Old May 26, 2010 | 09:05 PM
  #33
FORDF250HDXLT's Avatar
FORDF250HDXLT
hey.your getting her.taking ya a little while i see.
that's ok.think of all the green your saving!!!$$$$
keep going.the lock ring is pretty simple.
since you bent the float arm,your going to want to hook the wire back up and see where the gauge reads.make sure its close.
so if the tanks empty.you want the gauge to read below the red.OR just pay very close attention to where it reads.this way when you know its getting close to there again,you had better fill up or you'll be walking. if its not lose to E on the gauge,and the tanks empty,your going to want,to adjust it some more before you begin putting the straps on.or you'll kick yourself latter.
keep up the good work!!!! your saving loads of $$$$!
sounds like your getting close to the final hour now.
Old May 26, 2010 | 09:41 PM
  #34
powerstroker100
haha it was actually pretty easy the sending unit really stumped me and I actually lost a few hours time because of it (dont laugh!! lol) I packed everything up two hours ago going to start putting the tank back in tomorrow, I have so many things left to do for the truck though its extremely overwhelming
Old May 26, 2010 | 09:51 PM
  #35
FORDF250HDXLT
nah.keep pressing forward.before you know it,the list keeps getting smaller,and smaller,and the truck more and more reliable.
good luck tomorrow!
Old May 26, 2010 | 09:57 PM
  #36
powerstroker100
thanks do you by anychance remember which fuel line goes where on the tank, i forgot to mark the lines for which one was which, I don't want to mix them up its just those two lines you disconnect from the top of the sending unit also will I need to bleed the system now? of air
Old May 26, 2010 | 10:09 PM
  #37
FORDF250HDXLT
they are of difference size so you can't mix 'em up.no worries there.
likely yeah.you'll want to fill the fuel filter when your done and remember only crank the starter for 20 seconds at a time max.then stop.wait 2 minutes to let her cool down,then you can crank it again.if you dont let her cool between tries,your going to damage or simply kill it right on the spot.so be careful,they're pricey high torque suckers.
if no luck on the third try,i would stop and open a couple injector lines and try it again.just make sure to shut her down if it fires cus she'll spray fuel all over.tighten 'em back up and then start it.
Old May 27, 2010 | 05:26 AM
  #38
powerstroker100
okay thanks for all your help f250, how can I take the fuel filter off everybody I see says use a strap wrench but on the bottom of mine there is a metal cap what does that do
Old May 27, 2010 | 07:55 AM
  #39
greywynd's Avatar
greywynd
If you still have the second tank working, start the truck on it, rev it up some, and then switch tanks for a second or two, then switch back....do that 2 or three times, and it should get most of the air through from having your tank off. The engine may sputter a bit as the air from the lines goes through, but should keep going. If it does quit, and won't easily restart, then just start purging air as you would have anyway.
Old May 27, 2010 | 02:27 PM
  #40
Sycostang67's Avatar
Sycostang67
That metal cap houses the water in fuel sensor and has the valve to drain water from the filter. If you unplug the sensor and disconnect the drain hose, then you can remove the filter with that bottom lid still attached. It wont make as big a mess either.
Old May 27, 2010 | 03:35 PM
  #41
powerstroker100
okay guys got the truck all abck together few hours back, cranked it and she fired only was able to put in 1 gallon in the new tank lol, truck drove fine then all the sudden sputtered and cut, so its the piece of rubber I pulled off the bottem of the sender, but I replaced it with a hose cut like a v at the end it just wasnt catching that single gallon, so finally after bleeding through the shrader valve the truck runs fine now and has a nice 18 gallons in that shiny new tank, now I'm heading out to the international dealer to pick up a brand new CDR valve and hopefully some CAT red elc coolant after reading about oreo's cavitation problem,
Old May 27, 2010 | 10:32 PM
  #42
FORDF250HDXLT
excellent! job well done powerstroker.
Old May 27, 2010 | 11:27 PM
  #43
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Feels good don't it!
-Enjoy
fh : )_~
Old May 27, 2010 | 11:42 PM
  #44
David85's Avatar
David85
Now you have arrived......
Old May 28, 2010 | 10:44 AM
  #45
powerstroker100
haha yes it feel wonderful! and I would like to THANK EVERYBODY FOR YOUR HELP! I picked up my new cdr valve from international, the parts guy didnt know what it was at first haha, but in short I think its defective out of the box
hardwaterfreak
Nov 16, 2011 01:06 PM
uchitz
Electrical Systems/Wiring
Dec 19, 2009 07:25 AM
clydesride
Jan 31, 2009 08:16 AM
wader200
General Diesel Discussion
Nov 27, 2006 03:15 PM
