engine missing
Old May 30, 2010 | 03:50 PM
  #31
Visseroth's Avatar
Visseroth
Which sensor are you talking about?
Old May 30, 2010 | 04:21 PM
  #32
kupaa's Avatar
kupaa
also my mileage is terriable, 10-12 mpg unloaded
Old May 30, 2010 | 08:09 PM
  #33
Joe28443's Avatar
Joe28443
Joe28443
mine kinda reminds me of shifting into 5th from 2nd. The vibration part of it and the miss feels like Its not getting the fuel it needs
Old May 31, 2010 | 12:25 AM
  #34
cutlass's Avatar
cutlass
I also have this same issue with my e99. I've replaced the ICP sensor, IPR, (new) original black CPS, Throttle pedal with all new sensors, and performed the Hutch mod and added the AirDog. None of this has made a dent in the miss or stutter that I experience. I haven't done the 50 cent mod or even checked my UVH yet.
I've also been told that the issue could be an injector going bad. Using the AE scan tool I have no codes and it passes cylinder contribution test and injector buzz test.
Old May 31, 2010 | 01:30 AM
  #35
homesteader's Avatar
homesteader
Originally Posted by kupaa
if one injector is not firing will it be noticeable because it idles pretty smooth now but still can fill a slight vibration at idle and while moving. also when i start it in the morning if fill the exhaust manifold with my hand while its still cold and at idle and they all seem to be the same temp as each other, so i think they all are firing. My egts are still high, at idle its 400*, driving empty at 60 mph its 900*.
Chris did you do a buzz test? Chris you might want to use a laser thermometer and check right where the probe is at that should give you idea where your temps are at. Also you could check temp on your exh manifolds to see temp diff. They could all be firing at idle, but maybe one is not flowing as much. My temps at idle is 300 deg on my gauge, so don't know if 100 deg diff is a lot.
Old May 31, 2010 | 10:17 PM
  #36
Visseroth's Avatar
Visseroth
Huh, weird, maybe a PCM issue then?
I've heard good things about the PMT1 and 2, plan on doing that upgrade anyhow to smooth out my motor but I wonder if the E99's have a PCM that causes the engine to not run nicely.
Old May 31, 2010 | 11:48 PM
  #37
powerstroke8994's Avatar
powerstroke8994
What happens when you run a CCT? Sounds like either the under cover harnesses or possible failed IDM had that same thing happen countless time for a failed IDM
chesty
May 18, 2016 09:14 PM
Thedonk
May 18, 2016 10:51 AM
Broncoseth
1978 - 1996 Big Bronco
Apr 3, 2015 09:24 AM
Brett Baxter
Aug 26, 2014 09:25 AM
400Nut
Modular V10 (6.8l)
Mar 10, 2011 10:55 PM
