Some code help please
Old May 21, 2010 | 08:11 PM
Gun-Driver's Avatar
Gun-Driver
'06 F-250 6.0w/35,000 miles
Check engine light came on the other day (truck seems to run fine)
Last time this happened it was the EGR, so I cleaned the EGR then took it to my friends shop to have him read and reset the light.
It was showing the following codes:
P0263 - #1 cylinder contribution/balance faulty
P0269 - #3 " " " "
P0299 - TC/SC under boost
He reset the light and I have driven it a little since and the light stayed off and the truck runs good. The turbo will spool up to around 30psi when stomping on it.
Could the dirty EGR cause it to show these faults?
If not are these items covered by the 5yr - 100,000 mile warranty?
Old May 21, 2010 | 08:24 PM
liv's Avatar
liv
The egr valve will usually throw a low flow code or something of the sort. Don't remember which # it is. I guess It could contribute too your third code. The first two I don't think are related, but yes they would be covered under the warranty. Also your EGR valve is covered under the emissions warranty aka zero deductible. They will clean or replace it for free. You'll just have to give up your truck for a little while.
Old May 21, 2010 | 08:27 PM
gearloose1's Avatar
gearloose1
Don't even worry about diagnostics.
Worry about finding the best diesel dealer techs and Ford dealer within your driving range --- and let them worry about it.
Old May 21, 2010 | 08:29 PM
bismic's Avatar
bismic
Emissions warranty means no deductible for 5 yrs and 100k miles.
Old May 22, 2010 | 12:15 AM
Gun-Driver's Avatar
Gun-Driver
Thanks guys
I guess I'll just run it and see if the light kicks on again.
I would rather take the 1/2 hour and clean the EGR myself than give up my truck for a day or more at Ford.
I just wasn't sure about the codes and if would hurt to continue to drive it.
Old May 22, 2010 | 03:13 AM
bismic's Avatar
bismic
A stuck turbo can cause EGR codes but a bad EGR can not cause turbo codes.
You have something more than a dirty EGR valve.
Old May 22, 2010 | 05:19 AM
Gun-Driver's Avatar
Gun-Driver
OK thanks bismic
artfd
1997 - 2003 F150
50
Nov 29, 2017 06:37 PM
MyKidsToy
Modular V8 (4.6L, 5.4L)
Aug 15, 2012 04:49 PM
SubZero
Feb 14, 2012 07:20 PM
cerebixed
1983 - 2012 Ranger & B-Series
Aug 15, 2009 04:03 PM
techsuphunt
Escape & Escape Hybrid
May 1, 2008 10:28 PM
