DTC Codes with new replacement engine
Old Aug 15, 2009 | 03:18 PM
cerebixed's Avatar
cerebixed
Hi,
I have a '99 Ford Ranger 3.0 that has a new Napa replacement engine installed in it.
Check engine light came shortly after the installation of the replacement engine, and the codes showing are P1309 and P0401.
I've run the vacuum test on the EGR valve, the engine rpm dropped, which indicates the EGR valve is good, so I replaced the DPFE. Disconnected the battery to reset the codes and the P0401 came back. Not sure what else to check.
I've read posts about the P1309 code and unless there are some easy checks to do I am planning to take the truck back to the mechanic to troubleshoot this.
I'd appreciate any recommendations you have for figuring out these problems. Thanks!
Old Aug 15, 2009 | 04:03 PM
cerebixed's Avatar
cerebixed
Another question
I have a related (and probably dumb) question- can the truck run with the P1309 code occurring? I am committed to helping family move a couple of pieces of furniture and will not have this problem resolved by tomorrow morning.
I had seen a post in an earlier thread Rockledge had posted for reference indicating the CMP controls oil to the engine, but I also saw another post that indicated a Ranger can be driven with the CMP sensor disconnected and the computer will control ignition.
I can put up with less that ideal gas mileage but not fatal engine damage.
Thanks for your help.
Al_Cuevas
1997 - 2003 F150
93
Aug 13, 2016 08:50 AM
CdnArmyGuy
Oct 8, 2011 10:34 AM
deejdeej
Jun 10, 2010 09:51 PM
Xdrive
Feb 10, 2007 05:58 PM
Eric1997f150
1997 - 2003 F150
Oct 10, 2006 08:03 PM
