Question about side gas tank.
Old May 20, 2010 | 11:53 AM
JGreen236's Avatar
JGreen236
My truck has a 16 gallon gas tank and i'm looking at replacing it with a 19 gallon side mounted tank would it directly strap up just like the 16 or would I have to do some moving to make room?
Old May 20, 2010 | 12:31 PM
baffledinpa's Avatar
baffledinpa
Look at this link,
Auto Parts and Discount Truck Parts at Car Parts Wholesale.com
I checked and they have the dimensions,
16 gal tank - 42-3/8 in. length; 14-3/8 in. width; 11 in. height;
19 gal tank - 58-7/8 in. length; 12-1/4 in. width; 12-1/2 in. height;
This is replacement for an 83 F-150 XL 351W, I used it for an example.
Old May 20, 2010 | 12:33 PM
smashclash's Avatar
smashclash
see my thread. do you have a 16 gallon tank cause you have a shortbed?
Old May 20, 2010 | 12:36 PM
baffledinpa
That would also be a big factor, Long bed vs Short bed.
The above tanks were for a long bed truck.
Old May 20, 2010 | 12:47 PM
JGreen236's Avatar
JGreen236
Yea I have a shortbed truck. 16 gallons seems so small for a 351w
Old May 20, 2010 | 12:48 PM
Rogue_Wulff's Avatar
Rogue_Wulff
The 19 gal tank *may* fit under a 2wd short bed, but there is not enough room under a 4wd short bed. The transfer case is in the way.
Old May 20, 2010 | 05:43 PM
cadunkle's Avatar
cadunkle
It will not fit, you have crossmembers in the way. I had a shortbed F-150 with a worked over 302 and 4 speed, it sucked gas especially when towing. Simple solution is get a rear tank. You can get factory 19 gal rear tanks that drop in (find another bed or modify yours) or aftermarket 39 gal rear tanks that only need longer tank straps and removing spare tire hanger.
Old May 20, 2010 | 05:44 PM
cadunkle's Avatar
cadunkle
Oh another option, if you don't already have an overdrive trans, swap one in. It'll make a difference if you do much highway driving.
Old May 21, 2010 | 10:30 AM
JGreen236's Avatar
JGreen236
Have you guys seen the rubber gas tanks they sell on Bronco Graveyard? I wonder how those hold up.
Terpfords
Mar 25, 2009 12:41 PM
Noveske
13
Feb 10, 2009 10:46 PM
JTdesert
Jan 17, 2007 02:30 PM
davidsca
Sep 4, 2006 09:49 PM
1978 - 1996 Big Bronco
Aug 16, 2005 01:18 PM
