1951 Ford F1 horn questions
Hi everyone, this has been a great help to me posting on this site.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
A few questions about the horn wiring.<o></o>
<o> </o>
The wire that comes down the center of the steering column and out the end by the steering box, is this the horn wire?<o></o>
<o></o>
Next question, can anyone tell me what wires connect to what terminals on the horn relay?<o></o>
<o></o>
This will be a huge help and thank you,<o></o>
Mike<o></o>
<o></o>
<o> </o>
<o></o>
<o></o>
Mike<o></o>
Yep, that’s the horn wire but it doesn’t work the way you would think it should. So that the manufacture don’t have to run a hot wire inside the shaft, that wire grounds the horn relay to complete the circuit and blow the horn when the horn button is pushed and grounded.
Julie will be along with pictures and some real clarity soon.
Sure, this should help:
The "Hot Bus" is 6 volt power. With OEM wiring (6 volt Positive ground) that power comes from the "BATT" post on the Starter Solenoid. It's the same post the negative battery cable attaches to.
No change if it's 12 volt Negative Ground, you just need to make sure you use a 12 volt Horn Relay (and the "BATT" post on the starter solenoid will have the Positive Battery Cable hooked to it).
Make sure your horns are grounded really well and the ground connections are clean. I'd use 12 Gauge wire from the Solenoid and out to the horns with 6 Volt system. 12 Gauge is good if it's 12 volt. 14 AWG is too light for the truck horns.
Kart18
437
03-14-2018 05:20 PM
