Connvert C6 from Column shift to floor shift.
Old May 19, 2010 | 05:24 PM
SpectreZ91's Avatar
SpectreZ91
What's needed to convert my C6 from a column shift to a floor shift?
Do I have to buy a kit or did the C6's come with a floor shifter that I can look for in the junk yard/
Thanks!
Old May 19, 2010 | 10:55 PM
85e150's Avatar
85e150
Mustang or other floor shifters can adapt or aftermarket like B&M and other fine brand....
Old May 20, 2010 | 12:39 AM
SpectreZ91's Avatar
SpectreZ91
Cool beans.. I may want to convert and figured I'd see what is involved before I make the decision..
Old May 21, 2010 | 12:26 AM
85e150's Avatar
85e150
Earlier Mustang is what I'm thinking. Also, Early Bronco and some Rangers had a taller auto shifter.
When you start to work on it, look at the lever on the trans--some stick up, some stick down. (car vs. truck, not sure which is which) So figure out how it works and compare that to the geometry of the shifter you are looking at if you try to adapt.
Old May 21, 2010 | 12:30 AM
SpectreZ91's Avatar
SpectreZ91
Cool deal..
I'm doing a body swap and trying to get my ducks in a row.. That way if the column doesn't work right I can fall back on something else...
T_Cooksey88
Mar 17, 2016 11:23 AM
Jason Ellison
Nov 19, 2013 10:58 PM
JDBeck23
Sep 25, 2012 03:46 PM
flip4eva83
Apr 24, 2012 07:40 AM
Ferrariferg
Oct 25, 2011 08:59 AM
