400 engine mounts.
Old May 19, 2010 | 01:29 PM
likeshills08's Avatar
likeshills08
400 engine mounts.
Do the 335 series and the small blocks have the same design engine mounts?
Old May 19, 2010 | 10:26 PM
mark a.'s Avatar
mark a.
Some people call a 351 Cleveland a small block & it does share the same motor mounts & bellhousing as the s.b. but it is a 335. The 335 351M/400 motor mounts & bell housings are different & will not interchange with a s.b./Cleveland.
Old May 20, 2010 | 11:04 AM
likeshills08
thats what I was wondering, I have a 400, it is not interchangable with say a 302 or 351w? Sorry for not clarifying. I know the 400 has the big block bellhousing, so does the 400 have the big block style engine mounts as well?
Old May 20, 2010 | 09:24 PM
mark a.'s Avatar
mark a.
The 351M/400 won't interchange with any sb & the 351M/400 have their own unique motor mount bolt pattern that won't interchange with any other engine.
Old May 21, 2010 | 01:27 PM
grclark351's Avatar
grclark351
bigblock and smallblock are chevy terms, they don't translate to Ford applications due to the many differences.
i use 'large pattern bell' or 'small pattern bell' when describing the trans bolt patterns but there's still another that could cause confusion with my terms, the FE bell.
most technically correct would be
Challenger series bell, 5 or 6 bolt (221, 260, 289, 302/5.0, 351W & 351C)
385 series bell (351M, 429 & 460)
FE series bell (352, 390, 428 & others )
Jonnylightning
May 1, 2015 06:38 AM
rat49f6
Large Truck
Jan 13, 2015 04:23 AM
abranz
Jul 4, 2014 09:45 AM
scott haller
Aug 16, 2006 08:31 PM
