Ranger tailgate stuck
Old May 19, 2010 | 09:05 AM
StillAqua's Avatar
StillAqua
Is there a way to release the driver side tailgate latch on a 2007 Ford Ranger without using the access panel on the inside of the tailgate? I have a tonneau cover which can't be folded back until the tailgate is open. Is there a way to insert a shim or screwdriver into the latch from outside to release the clip? I suspect the plastic clip attached to the latch rod on the drivers side has broken. Passenger side releases.
Old May 19, 2010 | 10:50 AM
wtroger's Avatar
wtroger
Is the latch broke or is just one side stuck. My latch on my handle on my 03 broke on one side and I was able to use a screw driver to move the mechanism for that side from the handle area of the gate.
Old May 19, 2010 | 11:27 AM
StillAqua's Avatar
StillAqua
It's not at the handle, it's the driver side of the tailgate at the striker plate (?); the passenger side will release (I can hear the click and the gate comes out slightly, clicks back in when you push on the tailgate). I tried to see if I could slide a screwdriver or knife blade down between the side of the tailgate and the bed but can't see an obvious route to get at the mechanism to unlatch it.
Old May 19, 2010 | 01:24 PM
sandhillmike's Avatar
sandhillmike
spray PB Blaster into the latch mechanism, they frequently just stick if not kept lubed
rob17
6.7L Power Stroke Diesel
Aug 27, 2016 07:01 PM
bcuz1998
17
Mar 7, 2016 01:26 PM
MS86
Jun 24, 2015 02:57 PM
nightowl263
Feb 21, 2011 09:02 AM
neon4x
Jan 20, 2008 09:28 PM
