Can't open Tailgate...
Old Jan 20, 2008 | 03:52 PM
neon4x's Avatar
neon4x
1990 F150 XLT Lariat
5.0 AOD trans..
Went to open the tailgate the other day and the handle lifts and unlatches the passenger side but not the drivers side. It has a drop in bed liner which has a cover over the inside of the tailgate. Is there a panel on the inside of the tailgate that I can take off to access the rods that release the latches. If there is apprx where is it located? Best I can tell I'm gonna have to cut the bedliner cover on the tailgate to get at it as it is screwed on and seceral of the screws are inaccessible without the tailgate down.
I wolud appreciate any help !!! Thanks Guys
Troy
Old Jan 20, 2008 | 04:06 PM
95F350XL's Avatar
95F350XL
Yes there is a plate under the liner. I believe the screws are torx.
Old Jan 20, 2008 | 04:25 PM
66F100Again's Avatar
66F100Again
You have one other option too. Use a sawz-all (or hacksaw if you're patient); slip it between the driver's slide latch that isn't unlatching and the stud inside the tailgate jamb. Then, you can get the tailgate open...and remove the bedliner panel. You can access the rods inside; but it's more likely the latch that's gotten jambed.
Old Jan 20, 2008 | 04:54 PM
kcb37's Avatar
kcb37
If the rod slipped off of the handle you won't have to have the tailgate open to fix it. You just need to get the rod back in the handle. You will probably need a new bushing though.
Old Jan 20, 2008 | 09:28 PM
neon4x's Avatar
neon4x
Thanks for the help. Will try to tackle it tomorrow if its above 15 degrees..lol
Troy
cub22908
Mar 18, 2017 03:10 PM
Deuce3301
Jan 4, 2017 06:38 PM
c mobley
2015 - 2020 F150
Sep 5, 2016 01:16 PM
beautyandthebeast
Dec 1, 2015 08:00 PM
LeoJr
Feb 25, 2015 11:11 PM
