Tailgate rod retainer clips
Old Feb 3, 2009 | 11:04 AM
bcuz1998's Avatar
bcuz1998
Question Tailgate rod retainer clips
Hi all...can anyone give me a source for the plastic/nylon clips used to hold the tailgate release rods to the latch? I got some from Checker, but apparently they weren't the correct diameter and the pass side popped out again. For 74 F-250.
Old Feb 3, 2009 | 11:19 AM
rich51fordtruck's Avatar
rich51fordtruck
I just bought 2 from lmc truck for my 74 f100 because mine were broken. Worked great.
You can order from them online. lmctruck.com
Old Feb 3, 2009 | 12:15 PM
bcuz1998's Avatar
bcuz1998
Thanks! I'll give them a shot.
Old Feb 3, 2009 | 09:06 PM
73f100shortbed's Avatar
73f100shortbed
I used some clips from autozone in the Help! section
Old Feb 4, 2009 | 11:07 AM
bcuz1998's Avatar
bcuz1998
I got some of those from Checker Auto, but they popped right back out. I'll get some from LMC and see how they fit. Thanks for the suggestions tho!
Old Feb 4, 2009 | 11:26 AM
73f100shortbed
Thats odd because the ones I found were close to the original type
Old Feb 4, 2009 | 12:51 PM
fmc400's Avatar
fmc400
MSEE
I find it's best to first push the rod lock clips in, and make sure they snap through on the other side. Make sure they spin freely in the tailgate handle, and that they can't rock back and forth. Next push the rod in, and then finally rotate the clip around until it snaps into place.
Old Feb 4, 2009 | 04:29 PM
F250army45d's Avatar
F250army45d
Hey earlier thread talked of using metal ones from earlier model truck have not done so myself but maybe trine find these from a 68 or so.
Old Feb 4, 2009 | 04:52 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973/96 Styleside Tailgate Rod Clips
E6AZ5421952A .. Tailgate Rod Clip.
(E6AZ-5421952-A replaced E3TZ-1021952-C & D3TZ-1021952-A).
MSRP each: $1.11 // FTEpartsguy.com price each: $0.67.
Also available in the HELP section at NAPA. These same clips were used in myriad applications, including the door latch rods on 1979/91 Crown Vics.
The tailgate rods used on 1964/72 Styleside pickups are not the same diameter as the rods used 1973/96, so the clips (which are obsolete) will not work.
Old Feb 4, 2009 | 07:19 PM
bcuz1998's Avatar
bcuz1998
Ok..Maybe I didn't get the clips pushed into the latch all the way, so I'll check that too. There sure isn't much room to work inside that small opening, is there? lol
Thanks too, Bill. I did call the local Ford dealer and they had the mid 80's ones in stock as well, but I wasn't sure that they would work on the older latch. Thanks again!
Old Feb 4, 2009 | 07:23 PM
73f100shortbed
Did you unbolt the latch? It is a small area but if the latch is loose it isn't too bad.
Old Feb 4, 2009 | 07:31 PM
bcuz1998's Avatar
bcuz1998
Yup..prolly didn't help that it was a little nippy outside when I was doing this, but I'll give it another shot! lol
Old Feb 4, 2009 | 07:39 PM
73f100shortbed
LOL the cold makes everything tougher to do. I think you'll get it right the second time.
Old Feb 5, 2009 | 10:22 AM
NumberDummy
Don Sanderson Ford in Glendale AZ has 62 of E3TZ1021952C (the first replacement number): 623-842-8762.
Old Feb 4, 2010 | 01:22 PM
JohnBOV43159's Avatar
JohnBOV43159
These are the metal tailgate rod end clips from NAPA. 6 clips/3 sizes. The two smallest worked on my 77. PN# 735-1148.
