6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Not regening enough?
Old May 19, 2010 | 08:25 AM
astamp78's Avatar
astamp78
First, I am not complaining!!!
But I have noticed, say in the last 5 or 6 months, that my truck simply does not regen very much. It is very noticeable when it happens so I don't think I am just not noticing. But I literally think I have only done a regen maybe twice in 6 months! It used to be quit a bit more often. I drive maybe 800 miles a month for perspective, mixture of in-town and highway.
I have also noticed my MPGs from the lie-o-meter maybe an average of 1-2 MPG down from where they used to be, but attributed that to my new Mud-Terrain tires.
What do you think?
Should I just bite the bullet and get the Spartan DPF delete like I want? (Am only delaying because the aluminum in my Blackstone oil report was a little high)
Should I get it checked? (Take off my Banks tuner first...)
Should I ignore?
Old May 19, 2010 | 08:30 AM
senix's Avatar
senix
I average around 500 miles on mine when running empty. I have mine set on level 2.
I will regen around 150 when towing heavy. The tires will hurt the mpg's a certain amount.
I don't think I would worry.
Old May 19, 2010 | 08:57 AM
astamp78's Avatar
astamp78
I am on level 6 all the time
Old May 19, 2010 | 09:29 AM
senix's Avatar
senix
maybe I should try that...what are you running when you tow?
Old May 19, 2010 | 09:32 AM
map054's Avatar
map054
How do you know what level you are set at ? is there a way to set it
Old May 19, 2010 | 09:39 AM
senix's Avatar
senix
you have two options with the banks 6-gun. Either a switch, a simple **** to up the settings or it you have the Banks IQ. A PDA of sorts but much more. this you can read guages and change the settings plus videos, GPS and microsoft office.
Old May 19, 2010 | 10:47 AM
astamp78's Avatar
astamp78
Only because at first I thought the same thing, Senix and I are talking about the Banks tuner, not a setting for regen.
@Senix
I don't tow a whole lot, but usually switch to 4 for that. I like how level 6 performs the most, but it is hard to tell between 4 and 6 which gets the best mileage. Banks originally said that people tend to get the best MPG on 4.
Old May 19, 2010 | 11:27 AM
senix's Avatar
senix
@Senix
I tried to tow on 4 but I think that is a little much when you are grossing over 22K.
Old May 19, 2010 | 04:38 PM
ruschejj's Avatar
ruschejj
Iknow a guy that regens every 800 miles or so and his pipes are black, sooty, and there is a puff of black smoke every time he moves from a stop.
My truck regens every 150 or so when I tow and my pipes are amazingly clean.
They perform identically, very minimal different feel to them, nothing really gets your attention when you drive them both back to back. Very frustrating to try to figure out.
Old May 21, 2010 | 12:21 AM
dt75flh's Avatar
dt75flh
I had the same issue. started to go 600 miles between regens with the black smoke/ black tail pipes. (still didnt pu any mpg thou)
after 3 trips to the dealer they FINALLY replaced the dpf. no more black smoke/pipes. and it now regens about every 160miles when empty
Old May 21, 2010 | 05:49 AM
jrc55's Avatar
jrc55
I'd swear that you were talking about mine it regens between 650/700 miles since the reflash last year which is a tank of fuel, I have a 52 gal Titan tank.
buckmasters
6.7L Power Stroke Diesel
75
Jul 21, 2025 10:24 AM
my50F1
32
Aug 13, 2018 10:04 PM
Six7
Jan 25, 2017 08:28 PM
tracyclifton
Jul 1, 2015 10:08 AM
F16Vip3r
74
Nov 17, 2013 01:35 PM
