Diesel Fumes in Cab during Regen
I saw a few other threads on fumes, but none relating to the 6.7.
On the way in to work this morning, I get the "Cleaning Exhaust Filter" message. This was great because I still had about 15 minutes of driving left and it usually comes on right when I am pulling into my driveway. As soon as the regen starts, I can smell diesel exhaust/fumes in the cab (this is going 70 mph on the freeway). When the regen was done, the smell went away. Is this normal? I could understand if I was sitting still getting some exhaust in the cab, but moving at full speed everything should be blowing away. This is my 4th or 5th regen and the first time I have noticed it.
If it was a loose connection, wouldn't I smell it all the time then? Just trying to figure this out before I take it in to the dealership, waste half my day, and have them tell me they can't replicate the problem. I'm think I'm going to at least wait until the next regen and see if it happens again.
I will occasionally get an odor in the truck during regen. I wouldn't call it "diesel" smelling, more like superheated exhaust. It is shows up at different speeds, so I am sure there is some kind of eddy current with the wind playing out. I have looked over the entire exhaust system and everything appears to be in place.
But it is definitely not raw fuel.
I also get the 'odor' during regen. In my case, I think the fumes are coming in through the air intake for the hvac system at low speeds or when stopped. If I put the hvac in the 'recirculate' mode, viola, no more fumes!
In any event, the fumes are horrible, give me a headache! Wonder what the CO content of those fumes are???
jammer
jammer
jammer
jammer
No odor here, other than the smell of burning money after a regen.
Seriously, there are some reports of exhaust entering the cab as Rick stated. Those were due to an exhaust flange leak of some sort. This odor you describe sounds different though. I would be curious to know what the service dept. finds when you take it in.
I traded my 09 5.4 Cc4x4 F250 for a 2011 CC 4X4 F350 back in October. The first 11,000 or so miles (13782 as of 5 minutes ago) I didnt have the exhaust smell in the cab either. I thought it was just me but I looked around yesterday at the exhaust and found a fitting loose(You'll need a flashlight). If you lay underneath the truck near the oil filter looking up its almost to the top of the exhaust pipe. Just a tubing fitting(looks like 1/4 inch tubing), not sure where it goes but someone else may know. It had soot all around and the fitting wasnt even on the threads. I tightened it up before work ( I dont remember if it was a 16 or 17 mm wrench) and on the drive home this morning as luck would have it the truck went into regen and no exhaust smell this time. Just something to check.
Love this forum by the way. The most informative I have found.
On my way home from coffee this a.m. I noticed fumes at a stoplight. About 15 seconds later, the Cleaning Exhaust Filter message popped up!
jammer
I didnt even think about that fitting rattling. I had been hearing it(assuming thats what it was) rattle for a while but I just went to check it out and didnt hear it so far. I was getting that ticking noise that has been mentioned but it isnt there right now even with the truck warm. Maybe that fitting was bouncing around or even being pushed around by the exhaust flow and making noise, I sure hope that was it. I took a pic of the fitting , give me a few minutes and I'll post it.
