Regen Question and Possible A/C problem
Old Jan 23, 2017 | 08:12 AM
Six7's Avatar
Six7
Got 2 issues I need some input on for my 15' 250.
The first is concerning the regen. I have the ghost screen activated for the exhaust filter and while in regen I will watch the soot level percentage drop on the screen until regen is complete. A few weeks ago I noticed regen would stop before the filter showed to be empty while driving down the highway. For the past several regens it would not drop below 20% full. Was on the highway this weekend, truck began to regen and this time stopped at 25% full. MY concern is that the regen is not completely cleaning the filter as displayed by the screen. Has anyone else experienced this have an idea of whats going on?
Second issue is within the past week on two separate occasions I have found a small amount of water on my passenger side floorboard. Pulled the mat back and the carpet up by the bottom side of the dash was damp. Only thing I can figure is that its A/C related. The truck is only 2 years old and just over 15k miles so I would hate to think that the A/C already needs repair. Any ideas as to what's causing this?
Old Jan 23, 2017 | 09:23 AM
Deuce40s's Avatar
Deuce40s
For the regen %, that's normal. Mine will even stop at 35% occasionally if I end up driving through a town at that moment and slow down. I've never seen below 20%. It's as clean as it's gonna get.
Old Jan 23, 2017 | 09:36 AM
djousma's Avatar
djousma
Regens you are seeing are normal. As for the water on the floor. could be AC. do you have a sunroof? if so, one of the drains could be plugged.
Old Jan 23, 2017 | 11:03 PM
4df150's Avatar
4df150
Since my last ECM update my regens always go to 0% (unless I turn the truck off in the middle of one).
My A/C evaporation coil was replaced @ 8000 miles, truck was 7 months old at the time.
I would get dealer to check both problems while still under warranty.
Old Jan 24, 2017 | 04:47 AM
Just Strokin's Avatar
Just Strokin
With the Ghost Screen, you will probably never see it go to 0%. My CTS2 will go to 0% but then it is similar to TorquePro and not in sync with the Ghost Screen percentages. You situation is normal, so no worries. Drive the truck like you stole it.
I have seen my percentages drop to 15% a few times but most times it will only drop to 20% or 25%. What you are seeing is normal and would not consider it a problem nor worry about it.
Have you gone under the truck on the passenger side to see it the "through the floor" HVAC drain is clogged or other problem? Sometimes the drain gets clogged or doesn't open and water will accumulate. Might have Dealer check this problem if you rather not crawl under truck.
Old Jan 24, 2017 | 10:18 AM
senix's Avatar
senix
mine will go to 0%.
for the leak, sounds like you are still in the bumper to bumper warranty period, take it in.
Old Jan 25, 2017 | 08:28 PM
Six7's Avatar
Six7
Appreciate the response. This eases my mind about the regen and I will be taking the truck to the dealer for the leak!
madsal
6.7L Power Stroke Diesel
36
Aug 21, 2018 08:46 PM
Lil02Ranger
6.4L Power Stroke Diesel
Mar 5, 2015 11:09 PM
Grassman09
29
Oct 9, 2011 08:17 AM
EricHB
13
Aug 20, 2008 09:36 PM
Black450
Nov 19, 2007 02:25 PM
