CEL code P0299
Old May 18, 2010 | 09:36 PM
gearloose1's Avatar
gearloose1
Originally Posted by cheezit
ya I suspect a valve issue, Ive only seen 2 bad connectors.
The valve I have in there is so old that it is heavily corroded (salt) on the front side.
I strongly suspect it is the valve --- but typical of failures, it keeps not failing completely so it cannot be just reset.
So I wanted to see how long it can go on like this before I get annoyed enough to replace it.
Old May 18, 2010 | 09:39 PM
cheezit's Avatar
cheezit
man its a 15 min job even in a econoline. remove the intake air horn to get to it.
Old May 18, 2010 | 09:42 PM
gearloose1's Avatar
gearloose1
Replacing it prematurely would not satisfy my curiosity as to what causes the intermittent fault in the interim.
Plus it annoys the heck out of people with their $300 AE scanners, etc. who probably put in $10,000 of repairs when I put in $100.
Remember, I am the one who resets the computers and codes just for fun!
Old May 18, 2010 | 09:44 PM
cheezit's Avatar
cheezit
Remember your saying that to a person that uses 10k worth of scan tools everyday and has access to and can even rear a lab scope from time to time.
Old May 18, 2010 | 09:54 PM
gearloose1's Avatar
gearloose1
Yes sir!
Old May 20, 2010 | 04:32 PM
Rod Jr.'s Avatar
Rod Jr.
Got a call from the dealer today, they have ordered a center housing part for the inside of turbo. They told me there is a $100 deductable, should this be covered under the five year warrenty ? And will they give me the updated flash for computer ?
Old May 20, 2010 | 04:36 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
It should be.....the dealer that did my turbo replacement under warranty sent me a refund check after I paid the deductible. I'd definitely ask them about it.
Old May 20, 2010 | 05:31 PM
bismic's Avatar
bismic
Under the emissions warranty, you will not be charged for labor, diagnosis, or parts for any emissions control device or system for 100k (ie no $100 deductible):
Air flow sensor
Air Fuel Feedback control System and sensors
Cold start enrichment system
Electronic engine control sensors and switches
EGR system
Exhaust manifold
Fuel Injection System
Intercooler Assembly - Engine Charger
Power Train Control Module
Turbocharger Assembly
Also covered by the two emissions warranties (Emissions defect warranty and Emissions performance warranty):
All emisssions-related bulbs, hoses, brackets, tubes, gaskets, seals, belts, connectors, non-diesel fuel lines and wiring harnesses that are used with components on the list above.
Some dealerships charge you and then put the ownership on you and Ford to get the refund. All the dealerships I have been involved with have ended up NOT charging the deductible (even though they started out saying I owed the deductible). MUCH simpler that way.
IMO a good dealership will look it up and not charge you ...........
Old May 20, 2010 | 05:59 PM
gearloose1's Avatar
gearloose1
It would be worth giving a great tech a $100 gift card if they really did a great job on your truck!
Old May 20, 2010 | 06:07 PM
Rod Jr.'s Avatar
Rod Jr.
Ok thanks for the info, I will reference these posts and hopefully they will waive the deductable.
Old May 28, 2010 | 06:38 PM
Rod Jr.'s Avatar
Rod Jr.
Ok this is the update, got truck back today, dealer replaced cac boot, removed tubo and found excessive coking deposits on center housing assembly and corrision, replaced center housing tubo and road tested with 24 psi boost. No charge, as it was still under warrenty till 8-2010. They did not perform the latest flash.
ramsay
Oct 23, 2014 08:55 AM
Bullitt390
Jan 13, 2014 06:50 AM
emmagator
Jun 3, 2013 12:57 PM
rnolloth
Jan 16, 2009 02:27 PM
BulldogBob
Nov 12, 2008 10:00 PM
