OBDII Code P0299
Old Nov 12, 2008 | 10:32 AM
BulldogBob's Avatar
BulldogBob
OBDII Code P0299
I have a 2004 F350 with the 6.0. When pulling my camper up steeper grades, I get error code P0299. I don't see that code listed. Does anyone know what that code is and what the problem might be?
Old Nov 12, 2008 | 02:26 PM
tazo's Avatar
tazo
2005 Update Page 08 Diagnostic Codes P0276 thru P0567
I got this from the tech folder.
Old Nov 12, 2008 | 02:38 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
If you have less than 100,000 on the vehicle, take it to Ford Dealer and they'll fix it. Sounds like EGR valve or Turbo with that code. It will be a $100.00 repair.
Old Nov 12, 2008 | 03:47 PM
misterc's Avatar
misterc
Bob: P0299 is a "underboost" code. Actually it would probably best be called "boost outside of parameters" because there is no overboost code and I believe a P0299 will also be set on an overboost condition. Was your truck pulling well or did it lay down on you? If it was pulling well, it could have been an overboost condition due to vanes stuck in the turbo. I have experienced this condition on my truck and the turbo was replaced. The tech still believed that it was underboosting but 40 psi is not underboosting.
Old Nov 12, 2008 | 09:32 PM
emmagator's Avatar
emmagator
A few months ago I was towing my trailer, when the same code popped up. Truck never acted funny or anything, I cleared the code and havent had any trouble since. Is this something I need to worry about or take to dealer?
Old Nov 12, 2008 | 10:00 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
i would have it checked out, if its a reocurring issue , cause once your warranty is over it will cost you more than 100$ . unless you have somthing stored for the future...
Orangeoutlaw
Feb 16, 2016 11:51 PM
Excurvelle
Jun 5, 2015 08:31 AM
oxt127
Oct 28, 2014 10:52 AM
ramsay
Oct 23, 2014 08:55 AM
Scrambler81
Jul 27, 2014 01:45 PM
