Fuel Line blew off
Old May 17, 2010 | 06:02 PM
89F20plowtruck's Avatar
89F20plowtruck
Fuel Line blew off
So my brother and I have been putting our 5.8 windsor back in our 89 F250. We spent the afternoon hooking up the last few things and fine filled all the fluids to start the truck. After a few times of cranking it over, the line leaving the fuel pump blew off during cranking. Just wondering if anyone has any ideas why it would do this, other than just a bad connector. ( this could still be it since at this point I gave up for the night) Thanks for any ideas.
Old May 17, 2010 | 06:06 PM
DBGrif91's Avatar
DBGrif91
The line blew off at the fuel pump, or at the fuel rail?
Old May 17, 2010 | 08:10 PM
89F20plowtruck
the connector on the exit of the fuel pump. gas came rushing out. so the fuel pump is definately working. I am wondering if maybe the lines or the fuel filter could be clogged and cause this?
Old May 17, 2010 | 09:09 PM
DBGrif91's Avatar
DBGrif91
It may not be connected properly. Is it a quick connect or screw type connection?
Old May 18, 2010 | 06:34 AM
89F20plowtruck
its one of the quick connects. the hose is real short between the pump and the fuel filter so it should be a big deal to replace. I hope that its just a bad connector
Old May 18, 2010 | 07:41 AM
subford's Avatar
subford
Could also be a bad fuel pressure regulator (FPR).
If the FPR does not come off it seat or the return line to the tanks is pinched shut/plugged the pressure can go over 100 PSI and blow a hose off.
Old May 18, 2010 | 10:05 AM
F150xlt's Avatar
F150xlt
There are two size duck bill retainer clips used on the fuel
system lines.
The Black clips are 3/8 and the White clips are 5/16.
If you use the wrong size clip the line can blow off. Verify the
hose connection is good by grabbing the hose and give it a good tug.
You can purchase replacement clips in the Help section at
most auto part stores.
I once used the wrong size clip at the fuel filter connection and the fuel line
blew off while I was getting off the highway.
Old May 18, 2010 | 11:34 AM
DBGrif91's Avatar
DBGrif91
system lines.
You could even buy a completely new connector and get the new clips with it. Just make sure you buy the right size connector.
Old May 18, 2010 | 01:17 PM
89F20plowtruck
its a black clip and the connector to the fuel filter is a white clip so I will make sure I check that when i get the replacement hose. I am thinking that the return line, like subford said might be pinched. Thanks for all the input guys.
89F20plowtruck
any ideas on how to check if it's clogged?
Old May 18, 2010 | 01:40 PM
DBGrif91's Avatar
DBGrif91
This may be a no-no, but the best I could suggest is to pull the return line from the FPR, then shoot compressed air thru it. If you can hear it entering the tank then it's probably not clogged, or the compressed air cleared the clog or is powerful enough to get thru it, whereas returning fuel is not.
Others may need to chime in on this tho- don't act until they do.
Old May 18, 2010 | 01:55 PM
LCAM-01XA's Avatar
LCAM-01XA
If you had a black clip on the pump side and a white one on the filter side, the pump clip is wrong - the fuel lines are 5/16" and require a white clip on both ends. I don't think an all new hose will be needed, just a new clip should suffice unless the connector it slides through got all busted by the old clip letting go. The fuel system has around 40 psi pressure in it even with the return lines free to flow back to the tank, which is enough to blow the hose off a steel line if the clip used is too large.
Old May 18, 2010 | 04:52 PM
89F20plowtruck
ok great well since I just put the lines back on. I'm going to try and replace the clip on the line. if it blows the new clip off. then I'm going to try and run come compressed air threw the lines to check them. Thanks for all the help.
user_zero
Jul 18, 2016 09:19 AM
brk300
May 1, 2016 08:37 PM
Whitepos72
16
Jan 12, 2015 01:21 PM
racerman33
Nov 11, 2011 09:32 PM
wickedklown83
Jul 4, 2010 09:54 PM
