Swapping Seats
Old May 15, 2010 | 11:37 PM
nighthawk285's Avatar
nighthawk285
Swapping Seats
Hey guys, having a little more trouble than I thought I was going to with my seat swap so I thought I'd ask. I have a 1987 standard cab F150 that has a bench seat in it. I am trying to swap it out for a 40/20/40 split bench seat out of a later model year, but the mounting brackets are wrong. I was able to pull a lower mount out of a Bronce, but it still doesn't quite match the floor. SO, here are my questions...
Did they make any standard cabs in that year range (87-early90) with captains chairs to swap the mounts out of?
Has anyone done this? What did you do for the middle part of the seat? There won't be anything just bolt in, so I'm thinking custom fab.
Thanks!
Nick
Old May 16, 2010 | 02:03 AM
nighthawk285
bump for luck before signing off!
Old May 16, 2010 | 07:23 AM
chillmiller's Avatar
chillmiller
well i put bucket seats from an 89 in my 88 the 89 was an f250 ext cab mines a reg cab
Old May 16, 2010 | 12:23 PM
dawhits1's Avatar
dawhits1
If you search google, I know I've read about this issue before on one of the ford forums regarding swapping bronco seats into an f150....can't recall which one though
Old May 16, 2010 | 12:33 PM
Ed Bamba's Avatar
Ed Bamba
The first generation Lightnings had captains chairs. Not sure if the floor was different, but can't see why it would be. I had captains chairs from a 94 installed in my 91 Super Cab.
Old Jun 5, 2010 | 06:10 PM
nighthawk285
Ok, so I finally figured out what I needed to do and how it needed to be done for mine. In '94, they made a mount that is a solid stamped plate under the buckets and center that connect them all and mount right up with the floor.....HOWEVER, to fit my needs for my stereo equipment, that didn't work, as when it was all bolted down, it only had 3/4" of clearance between the plate and the floor.
SO, what I had to do was drill out all the spot welds for the legs on the plate, weld in a solid plate, and then bolt on the captains chairs mounts for '87-'91 pickups. No drilling in the floor was required, both buckets move independently, and they are soooooooo much more comfortable than the worn out bench. Here are some pictures, it took most of all day yesterday and I found out that welding+lots of beer=really bad welds lol.
THE MOUNTING PLATE
DRILLING ALL THE SPOT WELDS OUT
MOUNTING PLATE AS IT SITS IN THE TRUCK
FINISHED PRODUCT
Old Jun 5, 2010 | 07:27 PM
Diesel_Brad's Avatar
Diesel_Brad
You must be short to have the seat sit that high and not hit your head. I'm 6'4" and i only have a 1/2 inch between my head and the headliner
Old Jun 5, 2010 | 10:07 PM
nighthawk285
lol, I'm 6'0 but most of it is my legs, and yeah, that's me now, only bout 1/2 inch from the ceiling. Hit my head on the top of the A-pillar getting out today.....going to take a little getting used to.
Old Jun 6, 2010 | 05:59 AM
Diesel_Brad
I'm curious. Did you have to mount the seat pan higher for an amp or something?
Old Jun 6, 2010 | 10:59 AM
nighthawk285
yeah, I have 2 amps and a capacitor that fit under the seat
Old Jun 11, 2010 | 12:39 AM
Marine5811's Avatar
Marine5811
Dude your truck KILLS! Thanks for the help, too. Can't wait to try this out.
Old Jun 30, 2010 | 10:10 PM
Jnny600's Avatar
Jnny600
Spot
I don't really understand the drilling of the spot welds.
Old Jun 30, 2010 | 10:36 PM
Hitokori's Avatar
Hitokori
so he could remove the '94 floor mounts and install the '87 floor mounts
Old Jun 30, 2010 | 11:44 PM
nighthawk285
yeah, so I could put on the '87 floor mounts that make that floor pan sit up about 1 1/2" higher than it was with the '94 mounts so I could fit my stereo equipment under it......still working great!
And I did go shampoo the carpet too and got it all nice blue again, once I put that picture on here, I was ashamed
GN1220
Feb 11, 2017 05:53 PM
radeon1314
Jan 3, 2017 08:53 PM
enzos66
May 25, 2016 06:39 PM
firegod75
Dec 28, 2015 10:22 PM
Jesser02EX
Mar 9, 2014 01:20 PM
