Sponsored by: Real Truck
Noisy Rear-End??
Old May 14, 2010 | 11:31 PM
MadMatt65's Avatar
MadMatt65
Noisy Rear-End??
I have an 06 F-350 dually, 4x4 with the FX-4 option. When I am making turns there is a popping\snapping in the rear. Is this the clutch packs or what?!?!? VERY ANNOYING!! Anybody have any suggestions? It only has 53K on it.
Old May 15, 2010 | 09:22 AM
senix's Avatar
senix
sounds like you may need to service your rear diff. Do you have a LS diff?
Old May 15, 2010 | 11:57 AM
bill64's Avatar
bill64
was the rear diff. lube changed recently ? if it has a limited slip it needs an additive as well as the gear lube otherwise the clutch plates will chatter and or grab going around corners.
it could also be (limited slip or open diff) damaged side or spider gears
rdfenn3
Apr 2, 2011 12:56 PM
turbo740922
1997 - 2003 F150
Jan 6, 2010 05:49 PM
DieselOwnerNow
Mar 31, 2008 01:19 AM
toddn78
Feb 19, 2007 09:21 PM
geterdone
Sep 4, 2004 02:33 AM
