Sponsored by: Real Truck
Front D60 U-Joints episode
Old May 15, 2010 | 06:19 AM
2kdually's Avatar
2kdually
After 10 years, I finally am changing u-joints. Drivers side was rusted in so bad that the inner shaft bent just enough when pressing out that the c-clips will not fit with new joints. Can this shaft be salvaged?
Thanks in advance,
Dave
Old May 15, 2010 | 07:04 AM
iron1951's Avatar
iron1951
Did the shaft bend or just one of the ears that hold the u-joint bearing cups. I had one where the ear had bent and I could not get the new u-joint in. Bent it back and everything is working fine now. Used a big bench vise and put a long pipe around the drive shaft. Went slowly and checked often. Did not want to go too far in the other direction. The long pipe (4') was good because it gave leverage and a lot of movement at the pipe end meant small movement in the u-joint ear.
Old May 15, 2010 | 07:09 AM
2kdually's Avatar
2kdually
Thanks for the help. It was just the ear, the shaft is still straight. I thought about some all-thread with nuts and washers to torque it open.
Old May 15, 2010 | 12:35 PM
rob29956's Avatar
rob29956
Since you have it apart you might consider putting snap rings in to hold the axle u joints. I have heard it makes the u joints stronger and less likely to come out. I think you have to clearence the yolk or ear so they will fit all the way around.....
fluidp
Nov 4, 2013 05:33 AM
gpbullock
Jul 11, 2009 01:12 PM
dantsg
1997 - 2003 F150
Apr 12, 2008 12:21 AM
kawika
21
Aug 4, 2007 09:25 PM
ramon1943
Apr 5, 2007 10:45 AM
