Sponsored by: Auxito
rear brake question
Old Jan 6, 2010 | 05:00 PM
turbo740922's Avatar
turbo740922
rear brake question
I have a 1997 F-150 XL 4x4 with the 4.6 liter Triton V8 and rear brake drums. How do I adjust the rear brakes?
Old Jan 6, 2010 | 05:49 PM
steve(ill)'s Avatar
steve(ill)
drum brakes are self adjusting... if you just want to check them, or you are installing new, the easy way is to jack the tire up 2 inches off the ground and remove the wheel/tire. Pull the brake drum off of the 5 studs. at the bottom inside, you will see a small adjustable bolt, slotted on both ends that engages the shoes. In the center is a star wheel washer that drags on a spring. you can turn the star wheel one click at a time to get more tight or more loose. To check you turn the screw 4-5 click and then try to put the drum back on. If it slides on, takek it off and adjust 4-5 more clicks, etc... Once it will not go on, back off 5 click and then install the drum, that is it. The self adjuster will take care of hte rest as things wear.
351Cleveland C4
The Next Generation
23
Sep 23, 2013 06:00 PM
YoungFordAddict66
40
Jan 20, 2011 12:24 AM
pcctim
Apr 14, 2009 11:45 AM
Eric_F250
24
Mar 24, 2009 08:48 PM
