Speaking of rear windows, has anyone installed one? What's involved? I'm interested in a sliding one, JCW has one for $100. I guess it can't be but so bad, glass is glass.
after removing all trim inside cab and your old window, put the seal on the new window. take a thin diameter rope and run it all the way around the middle of the seal. it helps to have 2 people. put the window into postition, and pull the rope out away from the glass. it will cause the lip of the seal to flip over the cab. thats the easiest way I've found to do it.
