so im going to do the x,b code spring upgrade. I had found a complete parts list including the numbers from ford, i thought i bookmarked it but i guess not...lol. i cant seem to find it again. can someone help me out with a complete part list? . Oh its a 01 v10 4x4 limited
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
just got home, these are courtesy of Ed, you can go to his site and hit the 'find multiple parts' button. I was about to buy some generic stuff from Ebay, found his Ford stock was the same price, will definitely be buying from him(not saying you shouldn't shop around, cause you ALWAYS shop around)
ok, here ya go
3C3Z5560CB rear springs x2
F81Z5598FA LH rear block
F81Z5598GA RH rear block
N811667S436 rear u-bolts x4 320mm w/o aux
N620485S441 u-bolt nuts x8
2C3Z5310HA front springs x2
there is no diff on ethe front u-bolts so you can reuse them if you choose, if you would like to replace them just becasue then order F81Z5705BA(square seat) or F81Z5705ZA(ROUND SEAT) x4 and the nuts N805480S426 x8
shipping would be in the $180 range as the springs are about $45 ish each to ship.
ed
there is no diff on ethe front u-bolts so you can reuse them if you choose, if you would like to replace them just because then...
Type these part numbers into Ed's site to get the MSRP & Ed's discount price.
Type the number into the box, select Ford, then click on.. search.
btw: If Ed's away from his desk...and you need something quick, P/M or email me...I can look up anything thru 2001, give you the part number, the MSRP & Ed's discount price.
this is just my observation on the spring swap with the "X" spring $141 ea and the "B" codes $191 ea..... WITH a discount, why not look into the ProComp lift springs.
Hey drunkensailor,
I'm coming to VA beach in august on vacation. Do you know from the top of your head which hotels would be oceanfront and on/close to the boardwalk? I've only ever been there once and online can only get you so much. Thanks
