Defective Complaints
Old May 17, 2010 | 09:05 AM
  #61
saycheessee's Avatar
saycheessee
Originally Posted by rickatic
saycheese,
Wow, I am astounded at the level of dealership incompetence you have endured. This is the number 1 contributor to the bad reputation the 6.0 endures. It is also the ammunition supply line for the bashers of the 6.0's "huge warranty claims and a billion dollars in payout" rants. Maximums post has it right on. You need to find a dealer that knows what they are doing. You have been blessed here by the free advice of several of the top Ford Dealership Certified 6.0 technicians who help out on this site. Heed their advice and find a good dealer. I wish you well
Regards
I wish the Heck that one of those techs were close to me!!!!!! I would be more than willing to take my truck to either of them.. I want to thank all of them for all the wonderful help they have given me in the last few days. They have led me in the right direction and given me some wonderful advise in asking questions to the dealership to ask them questions so they would check different things that they were not checking until I asked for it to be checked.
Old May 17, 2010 | 12:14 PM
  #62
vloney's Avatar
vloney
Originally Posted by saycheessee
I'm going to try to leave it at the dealership in the morning.. I hope that It does it in the morning.. Not sure if it will do it enough to see on video now.. before they changed the number 2.. you would have been able to see it.. it would knock the change out of the ash tray. LOL. I will try. How is the best way to video to get the best affects??
What they need to do, before first startup, carry the IDS outside to the truck. Hook it up, go to power balance, THEN start the truck. The misfiring cylinders will stick out like a diamond in a goat's ***.
Old May 17, 2010 | 12:36 PM
  #63
gearloose1's Avatar
gearloose1
Use any reasonable late model digital camera.
Set it to video record mode.
Open the engine compartment and photograph it on the side most likely to be making the noise.
I want to be able to see how the engine "rocks" and correlate it with the noise.
Make sure you know where the mic is on the camera and to give it a "clear" path (like don't cover the hole with your finger) to the sound.
Remember --- the key is to get a good audio AND video sound track.
Good luck.
Old May 17, 2010 | 12:45 PM
  #64
saycheessee
Good luck.
Ok.. I'll see if I can get that tomorrow morning before I leave to go to work.
Old May 17, 2010 | 06:17 PM
  #65
cheezit's Avatar
cheezit
Im gonna side with the dealer did the right thing by just repalcing the one injector. As a tech we have limits as to what we can call bad/failed and injectors are touchy with ford. if we have one injector down say when it 60* outside it doesnt mean we wont have 5 of them down when its 40* so it really depends on weather the truck was tested after a cold soak at the best possible temp. Now if the weather did not drop far enugh to diag it its not a tech issue its a weather issue. been down this road before.
Old May 18, 2010 | 06:07 AM
  #66
saycheessee
I agree!... Not the dealers fault.. The dealer can't help how cold the weather got or not.
Old May 18, 2010 | 11:21 AM
  #67
4ord06's Avatar
4ord06
Someone needs to yank an OASIS to see what has really been done.
Old May 18, 2010 | 07:22 PM
  #68
npccpartsman's Avatar
npccpartsman
Yup--since it's warranty it should be posted.
Old May 19, 2010 | 06:19 AM
  #69
saycheessee
Ok so what does that mean??
Old May 19, 2010 | 09:31 AM
  #70
rickatic's Avatar
rickatic
Ford has an internal service work tracking program called OASIS. All dealer techs have access to the service. It will list any service or warranty work performed at a Ford dealer. Your dealer can pull one for you. It takes ten minutes if the computer is up. All the work on your truck should be listed. They are asking you for one so the knowledgeable techs can see what has really been done.
Old May 19, 2010 | 06:36 PM
  #71
cheezit's Avatar
cheezit
just an fyi the only work listed on oasis is work ford has paid for. they do not track oil changes and what nots.
Old May 20, 2010 | 06:20 AM
  #72
saycheessee
So who wants to look into this and see what they think??? Let me know...
Old May 20, 2010 | 06:21 AM
  #73
saycheessee
I've not had a chance to try to get the video. Today would have been a good day though.. Cool morning and shook like a jolt wagon. Wished I had more time this morning to get it.
FAITHPRO1
Mar 10, 2014 10:51 PM
