number dummy axle help
Old May 11, 2010 | 09:39 PM
FordNFishinLover's Avatar
FordNFishinLover
Was wondering if i could get any info on a rear axle from a 1984 f-150 4x4.
Possibly what gears or anything about it.
the tag reads: W F E R K 2 4 C 1 3 3 L 5 0 9 S 3 1 9 0
THANKS!
Old May 11, 2010 | 10:25 PM
Rogue_Wulff's Avatar
Rogue_Wulff
THANKS!
The 3L50 translates to a 3.50 gear, with limited slip diff, you lucky ...........
Old May 11, 2010 | 11:00 PM
FordNFishinLover
Awesome, i was hoping to hear that it would have higher gears!
As for the limited slip diff what does this do for me? Unsure of what it is.
Old May 12, 2010 | 06:21 AM
Rogue_Wulff
Limited slip means it has a clutch pack inside the diff, to limit the slippage between the wheels. Only downside, is you must be sure to use a lube designed for a LS diff, or go buy LS additive from ford.
The bronco I am using as a donor for my 4wd conversion has 3.50 gears, but no LSD.
Old May 12, 2010 | 09:17 AM
andym's Avatar
andym
Here's a good article on differentials. HowStuffWorks "How Differentials Work"
Old May 12, 2010 | 03:09 PM
FordNFishinLover
Ahh now i understand.
Okay so this next week im going to get the bed pulled off the donor truck and then get the axle off.
Now for the swap of the axles, is there any problems im going to be running into or anything thing thats going to be difficult?
What do i need to do about the brakes on the swap? Should i be rebuilding the whole rear drum or what?
Thanks yall.
Old May 12, 2010 | 04:34 PM
andym's Avatar
andym
Is this axle going into your '81 F-100? Some early 80's used a car 5 x 4.5" bolt circle so make sure you don't run into that problem. The '86 has a 5 x 5.5" circle.
Not sure about pinion length. It might be that the pinion on one axle is longer than the other and you could run into driveline issues.
And make sure you carefully inspect the donor axle for excess pinion play, wheel bearing damage, axle in/out play, and wear and tear on all the gears inside the differential, unless you are just planning to do a rebuild anyway.
Brake hardware is interchangeable between the two axles so just use whatever parts look best. I would probably keep your wheel cylinders because if those parts sit for a long time they will leak.
And don't expect the limited slip to work. At all.
Honestly, if it were me I would just pull the 3rd member and have it set up the way you want it.
RadioControlGuy85
Sep 26, 2014 06:44 PM
McFarlandkm
Dec 26, 2013 12:03 AM
85camaroman
Jun 10, 2007 08:26 PM
dburgess
Feb 5, 2003 06:47 PM
G_SHARPE
Nov 1, 2002 07:10 PM
