batt gnd
Old May 8, 2010 | 06:43 PM
greyghost85's Avatar
greyghost85
batt gnd
hey, fellas. where does the battery ground on a 300 six? what bolt?
Old May 8, 2010 | 08:15 PM
6fifty_f1fifty's Avatar
6fifty_f1fifty
That's a good question, one I will be asking as soon as my six is finished getting built next week. I neglected to photograph her coming out...
I would assume any bolt that doesn't deal with a seal would be ok, the whole block is good for a conducive ground right?
Old May 8, 2010 | 08:31 PM
parr4's Avatar
parr4
Battery ground cable terminates at G203...LH side of engine
Old May 8, 2010 | 08:35 PM
greyghost85
dave, that doesn't tell me anything, my friend. got a pic?
Old May 8, 2010 | 08:43 PM
Fordzilla80's Avatar
Fordzilla80
The previous owner of my truck just bolted my battery ground to the bracket above the alternator.I asked about that here before,and I was told that where it's at is just fine.I would like to put it back where it should be from factory so hopefully someone can provide an exact location for us.
Old May 8, 2010 | 08:57 PM
parr4's Avatar
parr4
Whatever bolt the ground cable will attach to is the one. Electricity doesn't care which bolt on the engine block serves at it's return path.
Old May 8, 2010 | 09:01 PM
greyghost85
i can tell by the bolt hole on the cable, that it isn't a very large bolt. i cant locate a bolt the correct size in the area that the length of the cable plays out to. could it be the starter?
Old May 8, 2010 | 09:04 PM
vwbill's Avatar
vwbill
I don't have a six or picture but have a evtm manual for '86 with a picture. G203 shows two connections from the battery cable. One bolt above the starter pointing down, between starter and block maybe. Then the cable goes under the motor mount and attaches with another cable to the side of the block, just above oil pan near front. Hope this helps.
Old May 8, 2010 | 09:13 PM
greyghost85
i will give that a shot, tomorrow. thanx, bill!
Old May 8, 2010 | 10:38 PM
JimsRebel's Avatar
JimsRebel
the ground connects to the back of the starter
Old May 8, 2010 | 11:16 PM
greyghost85
what do you mean by the back? there are two bolts that connect the starter to the block. do you mean one of those?
Old May 9, 2010 | 12:13 AM
300 Buster's Avatar
300 Buster
Hey greyghost, I'm not for sure on the batt cable (I believe it goes on one of the starter bolts),but make sure you get those body grounds hooked up before you turn anything on.I've seen some weird stuff happen if they are not,the ones from the firewall to the engine.I'd bolt that battery ground some place where you don't have to mess with it when you have to replace something,but maybe on the starter is a good place,that way you know it's disconnected before you pull the starter?I always use a good star or lock washer and a little dielectric (or regular if you don't have it) grease on the connection,that way you don't ever have to worry about if it's getting a good ground (-20* in wind and snow when it won't start and you have to crawl under it to check).Sounds like your getting ready to light the "beast"?
Old May 9, 2010 | 01:16 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
IIRC the negative battery cable on the i6 has three (3) connections, The battery clamp, a bolt terminal about 2/3 of the way down, and an end bolt terminal.
Obviously the battery clamp goes on the battery, the center one connects to the chassis, the end one connects under a starter bolt.
Also ensure you have a ground strap between the engine and chassis, chassis and cab, cab and engine, well as might ensure you have one from chassis to bed as well. Ground straps are extremely important.
-Enjoy
fh : )_~
Old May 9, 2010 | 12:13 PM
JimsRebel's Avatar
JimsRebel
YES
It is connected to the lower mount bolt on my engine, but either would work fine.
Old May 9, 2010 | 12:19 PM
JimsRebel's Avatar
JimsRebel
Starter wiring pic, 4.9
