rear axle question.
Old Sep 25, 2014 | 01:47 PM
RadioControlGuy85's Avatar
RadioControlGuy85
rear axle question.
hey guys.
what rear axles would bolt up to our truck? its a 85 f150 4.9 3spd.
Old Sep 25, 2014 | 06:58 PM
RadioControlGuy85
dose anyone know of a good detail rebuild write up for the 8.8?
Old Sep 25, 2014 | 07:18 PM
Franklin2's Avatar
Franklin2
Any axle from 1980 thru 1996 from a f150.
Old Sep 25, 2014 | 07:34 PM
firegod33's Avatar
firegod33
^^^ This. The 8.8 and 9 inch are both good axles. That said, I've broken 3 9s but never an 8.8.
Old Sep 26, 2014 | 07:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by RadioControlGuy85
hey guys.
Your truck could have an 8.8" (has an inspection cover) or a 9 inch (no inspection cover).
9" used thru 1986 in F150's, 8.8's introduced in 1983, thru 1996 would be similar.
Old Sep 26, 2014 | 10:10 AM
RadioControlGuy85
its a 8.8
the problem is replaceing the pinion bearing.
today we found out why one of the spider gears had alot of slop.its cause the thrust washer has completey broke apart.
so we are going to replace them.but we need a good write up on how to take the carrier out and how to set up the carrier once we put it back
Old Sep 26, 2014 | 01:19 PM
NumberDummy
There is no separate carrier with an 8.8 .. only the 9" has it.
8.8" pinion bearings (4621/4630) and cups (4616/4628).
Old Sep 26, 2014 | 02:43 PM
RadioControlGuy85
we need info on how we take the ring gear out to get the pinion out.
there like no write ups for the 8.8
Old Sep 26, 2014 | 03:00 PM
Franklin2's Avatar
Franklin2
It's a involved process. I just did a google search on "Ford 8.8 rebuild" and a lot of hits came up, including you tube videos. This the rearend that the mustang guys mess with, so there is a lot of info out there.
Old Sep 26, 2014 | 03:09 PM
NumberDummy
Once the 8.8's inspection cover (4036) is removed and the axles are pulled, most of the parts come out thru the back of the rear end.
Notice 4241, this is the locking pin...it has a nasty habit of shearing its head off. Getting the remains of the pin out of the 4221 shaft, can be a study in futility.
You will also have to replace the 4662 crush sleeve and the pinion seal (4676) which is accessed at the front of the rear end...once the 4851 companion flange is removed.
I suggest if you're going to make the repairs yourself, get a shop manual, because you will need it.
Old Sep 26, 2014 | 06:44 PM
firegod33's Avatar
firegod33
4204 is the carrier. I think you are referring to the third member on the 9 inch.
Saw556
2015 - 2020 F150
Feb 1, 2018 12:26 PM
rustfreemike
Apr 20, 2014 10:20 AM
385seriesHemi
Oct 26, 2006 07:36 PM
sharkins
Feb 22, 2001 01:31 PM
