Help me identify my axle codes?
Old Nov 1, 2002 | 11:29 AM
G_SHARPE's Avatar
G_SHARPE
I have a 1989 F-250, 351 W 5.8L 4WD. Can someone identifie my differential codes? The Codes are below:
Note: ^ means an upside down triangle.
Rear Axle tag reads:
Top line: V106C
Bottom line: 55 10 2 9 ^ 0
Front Axle tag reads:
Top line: 3.54 ^ E8TA T0
Bottom line: ^6 10311 - 1
Old Nov 1, 2002 | 01:44 PM
WXboy's Avatar
WXboy
My '95 F-150 had all the axel codes and such in the back of the owner's manual, so you might want to look at that if you have your owner's manual as well. If not, maybe the local Ford dealer can get you one.
Old Nov 1, 2002 | 03:20 PM
82F100SWB's Avatar
82F100SWB
Looks like you have 3.55 gears out back and 3.54 gears up front, mine has the same, 3.55 is a Ford ratio, 3.54 is a Dana...
Evan
86 F250 HD XLT Lariat Explorer 4x4 ex. Extended Cab: 460 with factory 2.25" catless duals to the muffler(still running the stocker aaargh)
/T19(syncroed granny low)/BW 1345/3.55 geared Full Floater 10.25 and Dana 50 TTB/ 265/75R16 Hankook FR04's on 16x8 Whitespokes(street tires... Need mudders)
78 F150, 351M/C6, eventually to be repowered with a 400
Old Nov 1, 2002 | 07:10 PM
cbwarrior's Avatar
cbwarrior
Post Help me identify my axle codes?
Selfhl1
19
Oct 23, 2015 08:44 AM
carguy94
1983 - 2012 Ranger & B-Series
Oct 8, 2015 06:32 PM
rchalmers3
Oct 19, 2013 09:00 AM
todd jo
Apr 4, 2007 10:32 PM
Ford heaven
Oct 28, 2003 11:41 AM
