Where do you guys think or know where the most accurate boost reading can be pulled from? Currently mine is tapped into the line from the spider to the map sensor.
I have tapped into my AIH delete plug in the intake spider. I have never had it T'd into the MAP line, but I doubt there is any real difference in the pressure readings.
From what I have read, and from people I trust, you dont need to do the AIH delete for any good reason, except putting in a the map sensor there. You can pick one up from Clay. Oh yeah, another reason you may want to do it, you pick up a spare relay incase your GPR goes bad.
