boost guage installation question
Old Mar 28, 2004 | 09:51 AM
gottaGTO2's Avatar
gottaGTO2
Question boost guage installation question
Just wanted to get some advice on where to take my boost reading from. I have seen some say to drill a hole in the intercooler duct just after the turbo and others say to just put a tee fitting on the line going to the MAP sensor (upstream of the relief valve or pressure regulator if you have one installed). which one of these is the best option and why?
thanks,
jeff
Old Mar 28, 2004 | 10:25 AM
HeatStroked's Avatar
HeatStroked
The simplest installation is in the MAP line. Cut the hose, install the "T" and run the line to the gauge. Just as accurate and much less hassle then the the drilling, tapping, bung welding of the intake horn.
Old Mar 28, 2004 | 10:55 AM
gottaGTO2's Avatar
gottaGTO2
I agree HS and thanks for the reply
jeff
Old Mar 28, 2004 | 11:13 AM
wlihntr's Avatar
wlihntr
i have read on a couple of manufactures sights that it is ok to install a tee in the map sensor for pre '99 psd's but you should tap the manifold after the turbo for '99 and newer. i do not know why but they made it clear they did not want you tapping into the map line on the newer trucks. try looking at www.westerndiesel.com they used to have the install instructions on their sight.
Old Mar 28, 2004 | 01:28 PM
gottaGTO2's Avatar
gottaGTO2
any idea why it would make a difference? It seems to me that the pressure would be the same in both places.
jeff
Old Mar 28, 2004 | 02:00 PM
HeatStroked
Think about it, Ford plumbed the line to the sensor for a reason, If the intake horn was a better location, it would be there.
I have an "02" with the boost "T"d into the MAP line. Works great.
Either location is fine, but why go through the haasle of welding, tapping, etc.?
Old Mar 28, 2004 | 02:09 PM
gottaGTO2's Avatar
gottaGTO2
well, since yours is an '02 and it works well thats what i'll do!! much less hassle. thanks again.
Old Mar 28, 2004 | 02:40 PM
wlihntr's Avatar
wlihntr
i dont know why, but i am guessing there must be a reason they do not want you to tap into the map line on the newer trucks(i did have the years worng '94-'97 in the map line '98 and newer in the manifold)
Old Mar 28, 2004 | 04:16 PM
gottaGTO2's Avatar
gottaGTO2
my guess is that the manufacturer wanted to stay away from anything that may throw an CEL and by tapping into the yoke they stayed far away from the MAP. this way nobody could ever blame their guage for damaging the MAP or causing a CEL. Like HS says it makes alot of sense to mount it in the MAP line if that is good enough of a place fo Ford to take their measurement.
jeff
Old Mar 28, 2004 | 05:08 PM
wlihntr's Avatar
wlihntr
i do not think you are getting my point...put it where ever you want
Old Mar 28, 2004 | 05:25 PM
gottaGTO2's Avatar
gottaGTO2
Whoa!!!
hey now no need to get testy i appreciate all of your input, and I do get and respect your POINT. If i put it in the MAP line 1st and something isn't right all I have to do is buy anothe piece of hose...............
relax,
jeff
69Cobra
17
May 10, 2010 05:29 PM
cdiddy
29
Feb 7, 2008 12:26 PM
Neal 97 250
61
Jul 21, 2007 11:59 AM
erik_bishop
22
Apr 14, 2007 06:49 PM
ehumaui
Sep 29, 2003 09:58 AM
