Sponsored by: Real Truck
Front end noise
Old Jul 26, 2010 | 03:28 PM
bigblue61's Avatar
bigblue61
Front end noise
About 3000 miles ago I replaced my stock front tires (235/85/16) with bigger duratracs (265/75/16). Now I have started to notice a noise and vibration coming from the front when the wheel is turned close to full lock. The truck will turn but it bucks the wheel as if it wants to straighten out. I have checked and there is plenty of clearance. Is this just normal for bigger tires or is there something else? thanks for your help
Old Jul 26, 2010 | 04:15 PM
ChargersFanInCO's Avatar
ChargersFanInCO
Sounds like a vacuum line is disconnected and you're in 4WD...Contrary to popular belief, there is a small amount of vacuum applied to keep it out of 4WD if the hubs are in auto...Vacuum unlocks them, and when the vacuum is killed (or a hose is disconnected) they engage.
Old Jul 26, 2010 | 04:31 PM
bigblue61's Avatar
bigblue61
hmm that sounds reasonable its that same type of feeling i'll check after dinner
Old Jul 26, 2010 | 05:07 PM
bigblue61's Avatar
bigblue61
just went out and flipped the 4x4 switch back and forth a couple times and the noise went away thanks a lot for your help
Old Jul 27, 2010 | 01:31 PM
ChargersFanInCO
Glad to help..
Old Jul 27, 2010 | 06:34 PM
Fordfanatic4life's Avatar
Fordfanatic4life
yea i would have said it sounds like front hub trying to engage aswell..
glad to hear you got it sorted..
Old Jul 27, 2010 | 10:15 PM
dchamberlain's Avatar
dchamberlain
This is technically inaccurate.
A full vacuum pulse (8.75 in/Hg or more) for about 50 seconds is used to lock the hubs. A lesser vacuum pulse (5.9-7.1 in/Hg) for about 15 seconds is used to unlock the hubs.
Except during the locking and unlocking pulse, no vacuum is applied to the hubs at all.
