7 Pin wiring question
Old May 18, 2010 | 01:03 AM
  #61
SpringerPop's Avatar
SpringerPop
I received word back from NumberDummy that he can't help in finding the part number for the harness you likely need.
He suggests you contact PartsGuyEd.
If Ed can't help, you are going to have to use the wiring diagrams and fab up your own.
If you have to do that, and need the diagrams again, let us know.
Pop
Old May 18, 2010 | 08:03 AM
  #62
damons's Avatar
damons
I might have half luck if I understood what was going on, are you guys saying I have something missing?
Old May 18, 2010 | 10:04 AM
  #63
SpringerPop
In Post #57 I alluded to that.
If you don't understand what is going on, we're going to have a difficult time helping you get this resolved. We can provide the information, but you need to be able to assimilate it in a way that allows you to take the proper action to correct the problem.
The only way around that is to have someone who does understand what we're saying come over and do it for you.
Pop
Old May 18, 2010 | 10:27 AM
  #64
damons's Avatar
damons
It was just alot of information. If you are saying my truck did not come with tow package originally, it sure looks like it when you look at the wiring harness by the hitch. I think I will just run a new wire and be done with it. It just seems weird that everything else works fine. Thanks.
Old May 18, 2010 | 10:41 AM
  #65
Brother Les's Avatar
Brother Les
These trucks were made to pull 'stuff'.... it would be very very strange if it did not come with some type of a 'tow package'
Old May 18, 2010 | 10:57 AM
  #66
SpringerPop
Believe-it-or-not, without the "tow package" they didn't come with all the wiring unless it got ordered or added. If it was factory-ordered, it got the receiver and all the wiring.
If it was added by a dealer, it got a "kit", which included the wiring harness with the 'doghouse" which I described above. When I got my truck it had a receiver, but all the electrical was missing. I was able to find the electrical kit on eBay a few years ago and installed it. That's how I know about this.
Pop
Old May 18, 2010 | 11:04 AM
  #67
Kajtek1's Avatar
Kajtek1
I bought my truck 8 years old and it was used by utility co for towing as well.
But evidently they never used electric trailer brakes.
To hook up brake controller took me over 1 hr to find the harness buried deep under the dash (would never find it without this forum help) than I had to plug the fuse for the brakes, than find wire taped at the rear gate, than replace the 6 prong with 7 prong and hook up trailer brakes wire.
BTW check local law for break away switch. CA require them on all trailers (having brakes what is over 1500 lb) and I had to retrofit the older trailer with it.
Old May 18, 2010 | 11:16 AM
  #68
damons's Avatar
damons
Kajtek1, just FYI, in case it makes a difference, this setup definitely has trailer brakes along with all the other options, the only thing we can pin down is how it's charging the camper/trailer battery.
Old May 18, 2010 | 12:05 PM
  #69
just another truck's Avatar
just another truck
I dont normally make this suggestion, if you head to a place that sells campers, they will normally have the electric control, as well as a harness there for install. Might be worth it for you to have the install done.
Old Jun 6, 2010 | 09:05 AM
  #70
damons's Avatar
damons
After attending Riffraff West, they guys have determined that I do not have the doghouse for the 39 & 40 towing relays, so I will have to come up with something else.
Justin03PSD
17
Jul 11, 2014 06:00 PM
pzp107
All Things Towing
May 17, 2013 08:12 PM
secolvin
All Things Towing
Sep 28, 2011 04:00 PM
07F150trucknut
Electrical Systems/Wiring
Jan 19, 2008 03:56 PM
dlterrell
Jul 26, 2004 12:34 AM
