7 Pin wiring question
Old May 11, 2010 | 01:53 PM
  #31
Brother Les's Avatar
Brother Les
I am almost 100% sure that the camper battery charger wire Is Not 'Hot' until the truck is running.
The 'running' lights will come on when you turn on the truck running lights (with or without the egn. on or at 'run').
But I don't think it is designed to 'charge' the camper battery unless the truck is also 'charging' the truck batteries. And that does not happened until the truck is running and the altenator is running. the truck batteries do not 'charge' it....the altenator does.
Old May 11, 2010 | 03:24 PM
  #32
SpringerPop's Avatar
SpringerPop
Les,
You are completely correct!
Pop
Old May 12, 2010 | 09:16 AM
  #33
damons's Avatar
damons
I guess I am still stumped. I put everything back together, and all works, except of course my charging wire. I am puzzled at this # 39, as mentioned above, the list of fuses/relay's go from 1-40 but the fuse box only goes to # 37. I had the truck running and could not get any power from the wire that the charging wire from camper is spliced to.
Old May 12, 2010 | 09:34 AM
  #34
SpringerPop
Is the small relay "doghouse" that's shown to the left of the fuseblock in this photo present? (Disregard the blue tape and the word "here", it's for another project). A '99 with the trailer towing package should have a total of three of these little doghouses under the hood near the main fuse block.
That doghouse and wiring are added by the trailer towing package, and are where two of the missing numbered relays are. If you take off that cover, you'll likely find a relay missing.
My truck came without the trailer towing package, at least the electrical part, and I had to add that doghouse, relays, and wiring.
Pop
Old May 12, 2010 | 03:22 PM
  #35
damons's Avatar
damons
Pop, unless I am missing something, I don't see any pictures.........
Old May 12, 2010 | 03:24 PM
  #36
Brother Les
'click' the word 'this'..
Old May 12, 2010 | 03:37 PM
  #37
SpringerPop
Rather than copy some or all of the photos to this FTE server, sometimes people use links to send other's browsers to another site to have a look there.
It's the real power and beauty of the World-Wide Web.
Pop
Old May 12, 2010 | 03:43 PM
  #38
BillyBob69's Avatar
BillyBob69
I can take a pic of mine when I get home in about 3 hrs. I have an early 99 and all of my wires are in use. Power, back up brake etc. I can post it later on if you want to compare.
Old May 13, 2010 | 12:54 AM
  #39
damons's Avatar
damons
Please do, then tomorrow after work I will look at mine and see if it matches. I just want to be able to check this before I go through the trouble of running a new wire from front to back.
Old May 13, 2010 | 09:19 AM
  #40
damons's Avatar
damons
Ok Pop, mine does look like that. In very front of the smaller three relays, there are two fuses, the left side (looking at front of truck) does not have a fuse in it, yours does. So now that we determined we match, is #39 relay one of those?
Old May 13, 2010 | 09:30 AM
  #41
SpringerPop
You missed the main point of my Post #34.
Is the DOGHOUSE to the left of the fuseblock present or not?
Pop
Old May 13, 2010 | 09:40 AM
  #42
damons's Avatar
damons
Crud. I THINK so, but now I'll have to see when I get home tonight. Sorry.
Old May 13, 2010 | 11:12 AM
  #43
SpringerPop
Here is a photo of the doghouses and fuse block with their covers removed, showing the relays and fuses.
Trailer battery charge relay and trailer back-up lights relay are contained in the doghouse in the left center.
ALSO, the missing "fuse" you don't have in Position 36 is the A/C Clutch Diode, so I'm guessing your truck doesn't have air conditioning.
It would be normal to not have anything plugged in that position if that is the case.
Pop
Old May 13, 2010 | 11:26 AM
  #44
BillyBob69's Avatar
BillyBob69
Pop
Sorry I forgot to take the pic. Mine looks just like Pop's but if you still want, I can do this at lunch.
Old May 13, 2010 | 11:50 AM
  #45
SpringerPop
The relay nearest the firewall is for the trailer back-up lights, and the charge relay is the other one.
Both Fuse 16 and 24 must be good for the charging current to appear in your 7-pin connector. Of course, that relay must be present, too.
Pop
