more CPS talk-cold starts and Stuff
i've been reading a lot of threads on the CPS and which is better and what not. I had the recall done about 2 years ago and have the GREY CPS. Since then it seems like since then my truck just hasn't ran the same, rough idles, power seems hit and miss depending on the day, have intermittent cold start problems in the winter (GP system tests out perfect).
Just wondering if these could be due to the grey CPS. I'm thinkin bout gettin one of the new ones (blue??) and see if that changes anything. what do you guys think?
Did you happen to look at rotational velocity values before and after the change using AE? I'd be curious to see what you found if you did.
strokin'_tatsch
221
06-17-2010 08:30 PM
