Riding mower question.
Old May 7, 2010 | 10:50 AM
donjamer's Avatar
donjamer
I just got a new to me riding mower..
It is a Sabre by John Deere 1538..
I don't have a manual so I figured I would ask here..
The problem is that this is a Hydrostatic drive and when the motor is off you can't push it easily.. It will move forward, but not reverse...
The question:
Is there a way to disengage the tranny to make it move easily??
It is in Neutral, but still feels like it is engaged.
If your out in a field and run out of gas your screwed
Old May 7, 2010 | 04:34 PM
bens99f350's Avatar
bens99f350
I don't have a JD, but on my unit there's a pin on the back you pull out and lock into place that disengages the trans.... maybe yours has something similar
Old May 7, 2010 | 08:00 PM
donjamer's Avatar
donjamer
Thanks Ben...
I will have to look for that..
Old May 7, 2010 | 10:24 PM
ford2go's Avatar
ford2go
I will second the fact that there should be some sort of a little lever to disengage the drive.
Also
1. NOT recommended to move it without disengaging.
2. On my new Cub Cadet, it's not recommended to move it very far even after disengaging. Don't know how common that is.
You might check out mytractorforum.com -- they're like the fte of tractors. They have numerous sections to discuss pretty much any small to mid size tractor. JD is well represented.
Old May 7, 2010 | 10:33 PM
fordtruckman's Avatar
fordtruckman
My JD has a little bar around where you would hook up a trailer and you pull it out which disengages the tranny.
Old May 8, 2010 | 12:00 AM
Ford_Six's Avatar
Ford_Six
The last JD I dealt with had a lever under the seat, but it was a big box store JD.
Old May 8, 2010 | 06:58 AM
ckal704's Avatar
ckal704
Ditto what the others have said. It'll have a hydro dump valve somewhere. Can vary from a "pull-out" type of rod in the rear frame above/around the trailer hitch to a lever/**** under the seat of just between the legs in front of the seat to a hidden lever up under the fender. Some older JDs kind of hid the dump valve. Most newer tractors have them in more visible places.
I am not directly familiar with this model, but all hydros, as far as I know, have release valves on them somewhere as every manufacturer recognizes that from time to time they must be moved under other than their own power.
Old May 8, 2010 | 08:59 PM
donjamer's Avatar
donjamer
Thanks guys.. I will check the places you recommended later in the week..
I will let you know what I find out
Old May 9, 2010 | 07:38 AM
rebocardo's Avatar
rebocardo
Some of the tractors lock the drive train if no one is sitting in the seat.
scottddove
Mar 6, 2010 10:42 PM
omni
17
Nov 16, 2006 05:04 PM
Bruker
Sep 9, 2006 12:12 AM
BondoFord
13
Sep 28, 2004 07:56 PM
