Sponsored by: Real Truck
filter oil recommendations
Old May 6, 2010 | 09:53 PM
Rays 2010 F250 6.4L's Avatar
Rays 2010 F250 6.4L
i will be doing the vast majority of the work on my new truck. Does anyone have recommendations on filters (brands) to use
fuel - oil - air?
not trying to open a can of worms I have used Fram with good success on my boats and old cars along with royal purple lubricant.
thanks for the advice
Old May 7, 2010 | 11:26 AM
bpounds's Avatar
bpounds
For the 6.4 this answer is easy. You want OEM oil and fuel filters. Both are patented and aftermarket filters will not be equal. OEM means made by Racor, and will be Motorcraft, International, or Racor labeled.
Air filter probably is not as important, maybe, but I would stick with the OEM regardless.
I like these two sources online:
Performance Truck Products (free shipping >$50)
Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Old May 7, 2010 | 01:48 PM
senix's Avatar
senix
You need to stick with OEM. There have been reports of those that tried aftermarket oil filter that did not fit. There off brand filters required a new cap and because of this it was not seating properly, starving the motor of oil.
Be very careful that whatever you choose it is identical. Best bet and safest bet is OEM for both fuel and oil.
Tip, use new motor oil for the o-rings before screwing the cap down.
Old May 7, 2010 | 08:38 PM
Rays 2010 F250 6.4L
thanks for the information
you guys are a wealth of knowledge
if you find yourself in Chicago send me a note I will owe you a pop/beer!
Safe Travels
Old May 7, 2010 | 08:47 PM
senix's Avatar
senix
Safe Travels
You know of course we need pics of your ride now!
Old May 8, 2010 | 09:01 AM
Charlie Bravo's Avatar
Charlie Bravo
There was some posts either here or in the 5.4 forum about Fram filters coming apart and blocking oil passages. A friend researched this. Without getting into a long write up, stick with Motorcraft, Wix or Purolator. Best, CB
DavenTn
Dec 6, 2016 10:58 AM
kboughton
2009 - 2014 F150
16
Jun 21, 2013 11:23 AM
Jim McCarty
Texas Chapter
16
Jul 19, 2007 09:50 PM
cody41
Feb 16, 2003 03:37 PM
Mike Earls
Mar 11, 2002 12:49 PM
