Radio interference when applying brakes
Old May 6, 2010 | 12:41 PM
vicv's Avatar
vicv
97 Expy stock radio w/single CD. No interference when driving/engine running, only when using brakes. Very bad static/snow noise like no antenna.
Brake lights are working fine. Any ideas? Thanks
Old May 6, 2010 | 07:17 PM
shorod's Avatar
shorod
Sounds like a grounding issue somewhere. Maybe you have a poor ground to one of the bulb sockets. Any chance someone wired in trailer wiring using Scotch-Loc connectors rather than the factory-supplied pigtail plug?
-Rod
Old May 7, 2010 | 06:34 AM
vicv's Avatar
vicv
Thanks for the reply Rod. No trailer harnesses installed. I'll pop the lenses and check the bulbs/sockets for damage or corrosion. Probably won't hurt to pull the radio unit and reseat all the plugs and antenna.
dieselsubmariner
18
Nov 15, 2015 06:58 PM
bly8397
Mar 14, 2014 04:11 PM
justplumducky
Jan 18, 2014 09:17 AM
galaxie641
1983 - 2012 Ranger & B-Series
Sep 11, 2013 02:49 AM
gavin
Jan 2, 2004 09:12 PM
