2001 B4000 AM radio interference
This interference correlates directly to tire rotation speed, engine rpm has no effect. Under about 5mph it won't make the noise, but over that you hear a pop more or less for every rotation of the tire and when you hit say 50mph it is just a steady static noise on AM only. Haven't pulled the head unit yet, checked several body grounds under the hood and all are good. Don't know if a damaged wheel sensor could cause an issue or not.
It may as the Ranger side seems to be very unhelpful/dead. I figured "2001 B4000" was pretty obvious on what the vehicle is especially when it is placed in the Ranger/B series area.
.......patience, grasshopper......
I say pull the radio out and look over the antenna cable connection. And then check the antenna side.
There should be a "radio ignition interference capacitor" attached to the coil pack. Is it there? Maybe try re-attaching it or even replacing it.
Also, keep in mind this: TSB 01-7-3
hombre292
Nov 12, 2014 06:09 PM
ssanto
Dec 17, 2006 06:10 PM
