dp install help
Old May 5, 2010 | 05:26 PM
crazer42's Avatar
crazer42
dp install help
so i got my f5 today got it all installed today, and when i turn it on noting appears on the switcher, i have tried to hold the left button to bet it out of no start, but it nothingmhappens, it will just sit there and crank it wont turn over!!! help please
Old May 5, 2010 | 05:29 PM
1999SuperDutyStroke's Avatar
1999SuperDutyStroke
How well did you clean the silicone off your contacts on your PCM?
And i hope your keys remained in your pocket from the time you pulled your PCM until you re-installed your PCM!!
Old May 5, 2010 | 05:30 PM
megawatt00's Avatar
megawatt00
Make sure the cable that goes into the back of it is in correctly. Some have been known to plug them in upside down
Did you folllow the instructions and the keys were not in the ignition when you installed it?
Old May 5, 2010 | 05:34 PM
crazer42's Avatar
crazer42
followed instructions totally, keys were far away and batteries were disconnected. i thought i did a very good job of cleaning the connections guess i will pull it again and re clean
Old May 5, 2010 | 05:47 PM
fisherman2626's Avatar
fisherman2626
I installed mine the other day and it wouldnt start so i pulled it out and recleaned the surfaces better and it started and worked fine. Probably the same problem your having its just not clean enough.
Old May 5, 2010 | 05:54 PM
megawatt00's Avatar
megawatt00
Check the cable that goes into the switcher first you can clean the pcm contacts too much
Old May 5, 2010 | 05:58 PM
fisherman2626
When you clean it again just clean it until you see some brass color that worked for me.
Old May 5, 2010 | 07:47 PM
F350-6's Avatar
F350-6
^^^^^^ My thoughts too.
Old May 5, 2010 | 08:20 PM
zx250's Avatar
zx250
Of the next Riffraff East
You did hook the PCM cable back up under the hood, right?
Old May 5, 2010 | 08:25 PM
PaysonPSD's Avatar
PaysonPSD
What Barry said . . . Plus tighten the bolt to ensure good contact on all the pins.
Old May 6, 2010 | 03:51 PM
megawatt00's Avatar
megawatt00
From your other thread it is in and all is ok. What did you find?
Krapfl
Aerostar
Feb 4, 2018 05:54 PM
James Hogan
Feb 17, 2017 08:18 PM
gotroxs
Jan 1, 2017 12:56 PM
POS Camaro
Aug 21, 2016 02:13 PM
mybigredford
Nov 4, 2014 09:01 PM
