Need help with Front Wheel Hub
I have a 2004 F250, CCSB, 6.0L, Fx4, Lariat.
I am trying to replace the passenger side front hub. I either have a bad hub, or I am not installing it properly. I have it installed with the locking hub unlocked and trying to turn the hub, the entire passenger side axle spins. It is also very hard to turn it. I strapped axle, and the hub is almost impossible to turn, with or with out the actual hub installed.
This is the second hub that I installed with the same results. I''m not ruling out bad out of the box, but it is the second one I installed today.
Thanks for your assistance.
I can do that. I'm thinking that the inner bearing might be the wrong bearing. It takes significant effort to install the hub onto the axle. I can get it up to the oring and then I need to use the nuts to bring it the rest of the way on. I'll see if there is a bearing number visible and see if it the same as the old one tomorrow.
queen of spades
1999 to 2016 Super Duty
03-22-2015 04:38 PM
