2004 supercrew 4.6
new front rotors and pads. step on he brake pedal and it feels as if the ABS is on. any pavement or dirt. I have re-bled the system and no change. It was doing it before the repairs.
One of the wheel speed sensors could have picked up some dirt or something damaged it. Look at the front sensors and see if you can see anything on them. also the rear can pick up metal shavings from wear in the diff. and throw off the sensor. One of the sensors could be bad too.
