Vibration While Braking
Old May 3, 2010 | 09:54 PM
Justin's Green Truck's Avatar
Hello, I have a 1977 F-150 Custom, 4x4, 351m.
Under light braking, there is some serious vibration that has developed over the last few days. When im at highway speeds and lightly depress the brake, a vibration builds up and it feels just like the right front wheel is about to fall off. If, during this, I jam the brakes on hard, the vibration lessens and is controllable. Today I pulled the right front wheel off and checked the rotor. The rotor spins very freely for about a half turn, and then drags really hard against the pads for the rest of the turn. Im wondering if the rotor could be warped.
All brake components seem to be tight, and the wheel bearings and ball joints seem to be in good shape.
Im wanting to know if anyone has experienced this with their truck and if these symptoms are indicative of a warped rotor. I have not measured the thickness of the rotors, but im reasonably sure they're the originals.
Thanks for any advice
Old May 3, 2010 | 10:03 PM
bamaf150's Avatar
bamaf150
Sounds like a warped rotor. You should feel it pulsating as well as it pushes the piston in and out as you brake.
Old May 5, 2010 | 05:33 AM
wdfp's Avatar
wdfp
X2 and those rotors are pretty inexpensive also, mine were around 40 or so for both I believe, and the pads are cheap also, just change both of them and be done with it..
Old May 5, 2010 | 06:11 AM
powersmoked's Avatar
powersmoked
+3 on your rotors........it is a little weird that it happened in a day.....check all front end parts also
Old May 5, 2010 | 09:36 AM
well, it didnt really just happen all of a sudden. Its kinda been getting worse over time.
I know you have to press the old hubs in and out of the rotors though and i dont have a press.
Old May 5, 2010 | 10:27 AM
MadFrank81's Avatar
MadFrank81
I can usually find a shop that'll press stuff for me cheap or even free, one guy just wanted a cold Mountain Dew!
Old May 5, 2010 | 10:52 AM
berry1234's Avatar
berry1234
Warped rotors is mostly a misnomer. Very few rotors are actually warped. The majority have uneven pad material build up. This can happen when the rotor overheats and the pad is left pressed against it-stop light after hard braking, etc. The pad material transfers to the rotor in one spot or unevenly causing the pulsation/vibration. There is a chance you can turn these and get rid of all the old pad material and be ok.
Old May 15, 2010 | 08:15 AM
Thanks for all the help
Old May 15, 2010 | 08:28 AM
Kalve's Avatar
Kalve
rotors bad need to have them check an the pads an brake lines while you are at it to be on the safe side.
Old May 26, 2010 | 04:06 PM
Well I found the problem, and it wasnt brakes. I noticed that the vibration started showing up even when I wasnt braking and thought that maybe it wasnt the rotors at all. It turns out that the trac bar bushings are completely worn out. I got up under the truck and it was very obvious what the problem was. So, Ive got some ordered.
How hard are these to change? Also, Im kinda worried that the trac bar mounts may be wallowed out from driving it with bad bushings. If they are, is there a fix for it?
F250_JR
23
Oct 30, 2018 10:02 AM
labman1014
Aug 28, 2011 07:06 PM
advocate
2004 - 2008 F150
13
Mar 25, 2011 06:43 AM
ford8n47
Nov 12, 2006 06:00 PM
cgl
Feb 3, 2004 02:12 PM
