Brake issue - vibration
Old Mar 22, 2011 | 07:11 AM
advocate's Avatar
advocate
I've had my 07 HD F150 into the dealer a few times for this issue and they have not been able to repair it.
When I use the brakes especially at higher speeds you can feel them turning like a warped rotor, sometimes it will make the steering wheel shake. It does it with both my summer tires (22") and my winter tires (17"). Even at slow speeds you can feel it.
The dealer keeps checking and says that the fronts are fine, last time they machined the rear rotors and said it was fixed. To me the fronts look pretty grooved but they keep saying they are fine. Which didn't make sense to me. The truck stops well and has good feel and power but I get this warped rotor feeling.
Is the dealer missing something?
Old Mar 22, 2011 | 07:18 AM
MCDavis's Avatar
MCDavis
How many miles on those rotors? Are they the original rotors that came on the truck new?
The factory rotors have been notorious for warping on our trucks. Turning them just fixes it temporarily as it removes a slight bit of material, but removing material also gives less material to dissipate heat, thus the warping comes back quicker most times.
I too have the same issue and will be addressing it this summer hopefully with an upgrade on rotors and pads.
Old Mar 23, 2011 | 07:00 AM
advocate's Avatar
advocate
40000 km on them, they are original. Been a problem since 20000 km. The truck does not get driven much but when it does this brake issue makes a nice truck have a bad feel. The dealer keeps telling me that the fronts are not warped... Maybe I'll just go somewhere else.
Old Mar 23, 2011 | 07:07 AM
MCDavis's Avatar
MCDavis
The vibration only happens when you're braking, correct?
Does the entire truck surge/pulse in rhythm with the vibration when braking?
Do you feel the pulsation in the brake pedal, or just the shaking of the wheel?
Old Mar 23, 2011 | 08:29 PM
advocate's Avatar
advocate
Just when braking, and yeah both the steering wheel and brake pedal, you can feel the truck pulse.
Old Mar 23, 2011 | 08:39 PM
bigunit54's Avatar
bigunit54
Sounds like warped rotors to me. I just changed mine last summer to duralast rotors with akebono pads. So far, so good. I would change them if I were you. Surprising the dealer hasn't recommended it, they usually want to make all the money they can.
Old Mar 23, 2011 | 08:53 PM
2007F150FX4's Avatar
2007F150FX4
My 07 has this problem as well. While the truck was under warranty the dealer turned the front rotors and replaced the pads. It helped for a few thousand miles and then it came back just as bad.
I assumed the front rotors were warped and ordered rotors and pads from Brakingperformance.com. I put those on and I still have the bad vib while braking. So I guess the rear rotors are the problem. Seems kinda strange the rear's are warped...
I'm just gonna drive it till the pads are shot and then replace the rotors.
Old Mar 24, 2011 | 10:13 AM
snowdog79's Avatar
snowdog79
My front rotors were replaced under warranty at about 32k because of stuck calipers, now the vibration is back (47k). Time for new non-OEM rotors and pads. Really the only thing I don't like about the truck other than the oil filter location.
Old Mar 24, 2011 | 10:56 AM
dgndngrngr84's Avatar
dgndngrngr84
+1 for the rotors. Yeah have them lube up the calipers too because they might be sticking.
Old Mar 24, 2011 | 08:00 PM
06'Scab's Avatar
06'Scab
New rotors at autozone for $30, one of my pads was completely gone and destroyed it!
Old Mar 24, 2011 | 09:28 PM
bigunit54's Avatar
bigunit54
I don't know how you got a new rotor for $30 from autozone. I put on the duralast rotors and mine were $51 a piece.
Old Mar 24, 2011 | 09:35 PM
bigunit54's Avatar
bigunit54
Never mind that last post. I just realized you were talking about the rear rotors and not the front.
Old Mar 25, 2011 | 06:20 AM
wp120470's Avatar
wp120470
Look at your rotors. On my bosses 06 model the rotors did the same thing. When I removed the wheels and inspected the brakes I found the front rotors were warped and both of them had bad heat cracks in them. Don't believe the hipe at the parts store either.We ordered Drilled and slotted rotors and installed ceramic pads now after 110,000 the heat cracks are back.Heavy truck too small of brakes. Get used to replacing them regularly.
Old Mar 25, 2011 | 06:43 AM
advocate's Avatar
advocate
hmm, maybe I will have to buy some good brakes for it then... On my last truck I put on a set of Napa rotors and their Ceramic pads, they seemed fine but I did not keep the truck too much longer after that to see how they lasted in the long run.
KJNDIVER
37
Aug 19, 2020 11:24 PM
F250_JR
23
Oct 30, 2018 10:02 AM
afonda
Apr 1, 2017 12:44 AM
Icefan71
1997 - 2003 F150
Oct 13, 2016 05:13 PM
Big Sky
Jun 2, 2016 09:42 PM
